Just saw this for the FIRST time on Ver. 1.0.19
Click on an e-mail and on the bottom I see this (Plain Text selected) :
The email was empty
account = Acct167697174
uid = 154f945c746a294cfd66c594bd91777d
file name = C:\Users\Irv\AppData\Roaming\Firetrust\MailWasher\cache\crypto\154f945c746a294cfd66c594bd91777dAcct167697174.0001
It is on the first 6 (UID and file name differ) of 29 e-mail messages sorted be time arrived.
Lines from the log file for above :
09-03-2010 07:28:12.144 Info S: +OK
09-03-2010 07:28:12.169 Info CALL POPservice::GetEmailLines(24, 380)
09-03-2010 07:28:12.208 Info CALL MWPmsgCache::CacheMessage(154f945c746a294cfd66c594bd91777d) NumLines 380
09-03-2010 07:28:12.284 Info S: +OK
09-03-2010 07:28:13.250 Info WASH Acct167697174 154f945c746a294cfd66c594bd91777d
09-03-2010 07:28:13.253 Info RBL CACHED ip=66.231.92.249 domain=bl.spamcop.net hits=0
09-03-2010 07:28:13.253 Info RBL Lookup: ip=66.231.92.249 domain=bl.spamcop.net cached=-1
09-03-2010 07:28:13.272 Info CALL MWPmsgCache::CacheMessage(b02f1075e85ef210ef5f7a1b3511d35b) NumLines 380
09-03-2010 07:28:13.275 Info S: +OK
09-03-2010 07:28:13.299 Info DO REGEX Acct167697174 154f945c746a294cfd66c594bd91777d
09-03-2010 07:28:13.299 Info REGEX START ispalten 154f945c746a294cfd66c594bd91777d
09-03-2010 07:28:13.304 Info REGEX DONE Acct167697174 154f945c746a294cfd66c594bd91777d
09-03-2010 07:28:13.304 Info RBL START ispalten 154f945c746a294cfd66c594bd91777d
09-03-2010 07:28:13.305 Info FIRST ALERT SUBMISSION START 4eb841d115e67be572d3090707692f3b
09-03-2010 07:28:13.306 Info WASH Acct167697174 80c523843ea297b0b221c898b9542933
09-03-2010 07:28:13.310 Info RBL CACHED ip=74.125.83.70 domain=bl.spamcop.net hits=0
09-03-2010 07:28:13.310 Info RBL Lookup: ip=74.125.83.70 domain=bl.spamcop.net cached=-1
09-03-2010 07:28:13.318 Info RBL DONE Acct167697174 m_uid = f480748a6b2392e46e6e90fdc929d562
09-03-2010 07:28:13.322 Info FIRST ALERT SUBMISSION DONE ispalten m_uid = 4eb841d115e67be572d3090707692f3b
09-03-2010 07:28:13.327 Info RBL CACHED ip=66.231.92.249 domain=sbl-xbl.spamhaus.org hits=1
09-03-2010 07:28:13.327 Info RBL Lookup: ip=66.231.92.249 domain=sbl-xbl.spamhaus.org cached=-1
09-03-2010 07:28:13.345 Info FIRST ALERT SUBMISSION START 154f945c746a294cfd66c594bd91777d
09-03-2010 07:28:13.355 Info FIRST ALERT SUBMISSION DONE ispalten m_uid = 154f945c746a294cfd66c594bd91777d
Odd?
Irv S.
Something new I've not seen before?
- anniebrion
Re: Something new I've not seen before?
Try installing the new Beta version (v1.0.20) from the beta forum.
- chantoine
Thanks.
The beta forum seems closed... have you got a link ?anniebrion wrote:Try installing the new Beta version (v1.0.20) from the beta forum.
Thanks.
- anniebrion
Yes it is closed but irvsp is a beta member as denoted by the green user name and will have access.chantoine wrote:The beta forum seems closed... have you got a link ?anniebrion wrote:Try installing the new Beta version (v1.0.20) from the beta forum.
Thanks.
- Sidewinder
- Weary Womble
Not quite ready for "prime time". New version next week.chantoine wrote:The beta forum seems closed... have you got a link ?anniebrion wrote:Try installing the new Beta version (v1.0.20) from the beta forum.
Thanks.
- irvsp
- Knowledgeable Kea
I can wait. I re-booted and all the e-mail messages came in OK? I suspect a POP3 server problem and it wasn't handled at all by MWP, well, it was handled as you saw, while I would have liked a message telling me there was a server error, re-try later (assuming it would work then?).
Irv S.
Irv S.
I get that message a lot but it only seems to happen when the MW/server link is under a heavy load. Not sure if it is a MW or POP problem but you could send the logs to Firetrust (from help menu) and see what they say.
Put in a link to your post here (right click the white icon by your user name to copy the link) and put Chris in as the ticket number.
- Sidewinder
- Weary Womble
Did you happen to see the error tab flashing?irvsp wrote:I can wait. I re-booted and all the e-mail messages came in OK? I suspect a POP3 server problem and it wasn't handled at all by MWP, well, it was handled as you saw, while I would have liked a message telling me there was a server error, re-try later (assuming it would work then?).
Irv S.
- irvsp
- Knowledgeable Kea
I had also sent off the bug report via HELP, so we'll see what happens?
Irv S.
Irv S.
- irvsp
- Knowledgeable Kea
Doesn't flash for me either, did a filter to catch these sneaky ones and keep them to the top of the grid so I know a re-check is in order.
It's always a MailWasher issue this one...
I know it's a few days old Irv, but have you seen this happen since. Do you know if at the time your machine was going under some other heavy processing ?
- irvsp
- Knowledgeable Kea
Rustic, I'm sure it was, but it always is loaded at boot... however, sometimes of course there are different 'things' active during boot, an update either being searched for or even d/l'ed. I'm considering delaying MWP on boot now? I have 2 programs that would do this for me.
It was the first time I've ever seen this, but it seems others have before.
Irv S.
Irv S.
You could set MW not to check on startup, and just let it wait for it's first automatic check instead. If you were checking every 5 minutes you'd probably barely notice, that said some servers don't like checking too often.
urgh....just had aftershock while typing this
I think a delay option within MailWasher is probably in order though.
- irvsp
- Knowledgeable Kea
Rustic, yes, I guess I could stop the on-load check, but I'd rather have that happen than wait 10 minutes? I usually open MWP the first chance I get to see what e-mail came in.
Delay option would be difficult, other than a delay on first check I guess?
There are a slew of programs that can delay start of programs, I'd rather use one of them.
What aftershock, where are you?
Irv S.
Irv S.
