Can't update Version 2010 1.0.15
lin_kot
Sat Sep 04, 2010 3:29 am
I am a LONG time user of MailWasher Pro ... I came to the forum because MailWasher Pro 2010 'drove me.' I needed to see if others find it very buggy ... I see an update is available but when I check for Updates, the message is "Your software is up to date." So ... I'm posting! Your help will be appreciated.
Re: Can't update Version 2010 1.0.15
Sat Sep 04, 2010 3:31 am
Look at the top topic in this forum there is a link to download v1.0.19. Download the file and then execute it and it will do the update.
lin_kot
Sat Sep 04, 2010 3:58 am
Thanks. I did see that link but didn't want to take a chance. I just updated my antivirus without uninstalling the existing and had an issue. So, I assume I don't need to uninstall MailWasher Pro ... just download the file and execute.
Sat Sep 04, 2010 4:38 am
lin_kot wrote:Thanks. I did see that link but didn't want to take a chance. I just updated my antivirus without uninstalling the existing and had an issue. So, I assume I don't need to uninstall MailWasher Pro ... just download the file and execute.
You are correct.
lin_kot
Sat Sep 04, 2010 5:28 am
Many thanks.
Also posted to indicate the Update feature isn't working. MW requested feedback in their announcement.
Sat Sep 04, 2010 7:23 am
They worked on the update a bit for .19 but there may be more needing done, you can subscribe (link at bottom of topic) to the new version topic and get an e-mail letting you know it is available. Give the updater a shot at it (from the help menu) and if it still misses post back so the firetrust folks know more work is needed.
lin_kot
Sat Sep 04, 2010 7:59 am
Thanks!
Would like to signup for notification but don't find the link at the bottom of the page ... http://forum.firetrust.com/viewtopic.php?f=50&t=7265
Guess I have the wrong page ... would you please provide URL for the right page?
Many thanks
Sat Sep 04, 2010 8:11 am
lin_kot wrote:Thanks!
Many thanks
Very bottom of the page on the left:
MWP Subscribe.png (2.94 KiB) Viewed 9788 times
Be sure an click on the Subscribe and it will then change to Unsubscribe.
You will have to Subscribe to the Forum or just check back periodically and look at the top of the forum.
The topic itself gets removed and a new put in its place so the subscribe will not likely work.
The auto update function was fixed in .19 so you should get a pop up notice when the new one goes live.
Sat Sep 04, 2010 8:14 am
There may be an issue with the subscribe working if rusticdog is deleting the old post and creating a new one but it is worth a try. Even if it fails you can check the version number in the title and see if it is new on any forum visit.
lin_kot
Sat Sep 04, 2010 1:52 pm
Thanks so much for all of your help ... you stuck with me from start to finish and it is very much appreciated.
Warmest wishes,
LinK
Sat Sep 04, 2010 1:55 pm
Glad we could help, the official firetrust folks are slacking off since it is Saturday :snore there and they had a big earthquake that did a lot of damage. :shock:
jfeat
Sat Sep 04, 2010 8:19 pm
I cannot update from 1.0.15 to 1.0.19 using the update tool. It worked fine for each of the previous updates, but not now. I will download the new version & update 'manually'.
jfeat
johnfairweather
Mon Sep 06, 2010 9:24 am
Likewise, clicking on 'Update', I get a message saying that my software is up-to-date. I only found that there was an update, by clicking on my 'Windows Updater', just by chance.
Tue Sep 07, 2010 1:41 am
johnfairweather wrote:Likewise, clicking on 'Update', I get a message saying that my software is up-to-date. I only found that there was an update, by clicking on my 'Windows Updater', just by chance.
Can you clarify this last statement, which Windows Updater told you there was a MailWasher update ?
We are really starting to draw blanks on why the update process is being so unreliable for some folk. We think we have all the kinks worked out, but it just seems to tell some folk they are up to date. I was thinking that possibly some ISPs that do heavy caching might be caching the file that is streamed in, so MailWasher isn't actually checking the file against the live copy on the server, but a locally cached copy through the ISP that's not yet up to date.
Tue Sep 07, 2010 5:55 am
Isn't the update file on the server HTML? If it is could you set a short expire time on it to keep it from being cached for long?
http://www.web-caching.com/mnot_tutorial/how.html
