Cannot get outlook.com address to work in MailWasher Pro
ChrisKoiner
Mon Jul 28, 2025 5:40 pm
I have tried the "Import Accounts" and also tried to manually put in the info for my outlook.com account, but I always get "Failed to login to IMAP server" error.
Could you give me detailed directions on setting up an outlook.com address in MailWasher Pro? Thanksamillion!
Re: Cannot get outlook.com address to work in MailWasher Pro
Tue Jul 29, 2025 6:04 am
Yes, sure thing.... can you first please open MWpro and click Help>>About, if not using version 7.15.41, install this from here:
then, delete the problem email account first:
Settings>>Accounts, click the account>>Remove Account.
Click File>>Exit to close MWpro, then re-open it.
Then setup the account again exactly as below:
Click the Incoming tab and click "Sign in with Microsoft", follow the prompts and you'll be asked for permission to allow MW access to the account, ensure you agree to this.
Any problems, just reply back....
ChrisKoiner
Tue Jul 29, 2025 12:33 pm
That got it to work... thanksamillion! Apparently the importing the account from Outlook didn't work originally.
