Editing filters
jmparsons
Editing filters
Mon Sep 06, 2010 3:45 am
When I try to edit a filter after I have created and saved it, I get an error message, "A filter with that name already exists."
Is this a known issue, or is there something I am doing wrong? I'd hate to have to recreate a filter just because I wanted to tweak it.
Joe Parsons
Re: Editing filters
Mon Sep 06, 2010 3:58 am
Are you on the latest version of MW? Check the latest version topic at the top of this forum to be sure. As I post it is "New MailWasher Pro 1.0.19"
Easy workaround is to just add or remove a period at the end of the filter name with each edit but I thought this was fixed in .19.
jmparsons
Re: Editing filters
Mon Sep 06, 2010 4:24 am
Huh! Looks like I am stil on 2010.1.0.10!
Updating now.
thanks!
Joe Parsons
jmparsons
Re: Editing filters
Mon Sep 06, 2010 4:27 am
I just checked for updates and got a message that I am up-to-date.
Do I have to download the .19 version manually?
Re: Editing filters
Mon Sep 06, 2010 4:38 am
There are glitches in the updater, it is better in later versions but I still check that topic to make sure mine hasn't missed anything, too the check is weekly so you could be missing out on shiny new goodness for almost a week while waiting on the updater even if it is working perfectly for you. :-)
The manual update is easy enough, the new version topic tells you anything you need to know about the new release.
