Starting yesterday and today Mailwasher will check the emails and will just hang while evaluating for hours until I have to use Task Manager to close it out. Starting it up again it seemed to get my emails but all of the Status were missing, no Spam, Blacklist, Friend, just blank. I tried sending the report and got an error again so I am emailing the error log.
Oh, I am using version 2010 1.0.19 but have had to go back to my old version of 6.5.3 since this new one is useless right now.
Hangs, Loops. Locks up
Re: Hangs, Loops. Locks up
Looks like it's FirstAlert again. I do get your logs too, so don't worry about the error you see.....what's happening there is it's failing to send through your account, but then as a fallback it sends through the Firetrust mail server which is working.
I don't know if you got my last email to your webmaster account, but I think it's failing to send the logs the first time as you had a type in the Email Address field of the account, and the domain isn't matching.
So switching off FA will temporarily resolve the issue
http://forum.firetrust.com/viewtopic.ph ... 059#p39059
- TopThumb
I've looked for any typos and can't find anything wrong. All of the email accounts were imported from the old MW when I installed 2010 version so they should all be the same. The old MW still works fine with all the emails. I'll look again though.
It's the 'Thumb Thumbweb' account, just check the email address entered there under the General tab for the account.
