Files for blacklist/whitelist
- Toucan
Which actual file(s) carry the blacklist/whitelist and can a list of addresses be cut/pasted straight in?
- anniebrion
Re: Files for blacklist/whitelist
MWP.db3 Info is here: http://forum.firetrust.com/viewtopic.php?f=50&t=6270
It is a database and not a text file so you cannot C'n'P into it.
You can create a text blacklist in the MW v6 format and use the 2010 blacklist importer to bring it in. If you need the format you can search by a post I made a while back on my "hate everyone" blacklist.
