Previous update still there
Old-Timer
Mon Sep 27, 2010 5:38 am
I still have my previous update of MWP (6.5.4) on my desktop, together with version 1.0.19. Perhaps I should have uninstalled it when I updated, but I'm reluctant to uninstall now because I think I might delete some shared files, etc.
Can someone insure me that all will be well if I uninstall? :?
Thanks,
An Old-timer trying to keep up
Re: Previous update still there
Mon Sep 27, 2010 6:08 am
Old-Timer wrote:I still have my previous update of MWP (6.5.4) on my desktop, together with version 1.0.19. Perhaps I should have uninstalled it when I updated, but I'm reluctant to uninstall now because I think I might delete some shared files, etc.
Thanks,
There are no shared files between the two versions so what your are proposing should not be a problem.
racker
Mon Sep 27, 2010 6:25 am
Thanks,
MWP6 can perfectly co-excist with MWP 2010; provided you didn't install them in the same directory.
Upon installation, MWP2010 imports some (not all) settings from the earlier installation, and saves them in a seperate database.
After successfully installing 1.0.19 you should be able to safely uninstall the older version if you'd wish to free some disk space.. But as we say here in the Netherlands: as long as it doesn't eat any bread, why uninstall?? ;)
:!: If you wish to uninstall, take care to pick the right version as they both have the same name and icon. Here on my system MWP 6 takes 22.16MB, and the new MWP 2010 only 17.83MB :!:
Beta tester.. oh well! ;)..
MWP FAQ
Old-Timer
Sun Oct 03, 2010 7:18 am
Thanks for the replies. I think I will keep the old version as a safety back-up for a while, knowing I can safely delete it when I want to. Thanks for the tip on file sizes (I was a little unsure when I first looked at them).
