As shown by the pic, MWP is no longer picking up the plain text filter that worked fine in the previous version.
Filter no longer works after update to 1.0.27
Re: Filter no longer works after update to 1.0.27
I assume that's the only Rule in that Filter ?
Can you look at the email in Source tab in the Preview screen, and copy/paste the contents of that to me into an email to [email protected]
- mr.den
No, it is not the only rule in that filter, but it does work when I change 'Subject' to 'Entire Message'.
Email sent
Email sent
OK great, maybe if you email me a screen shot of the full filter as well, so I can be sure I'm testing with the same.
- mr.den
Nothing arrive unfortunately. Can you forward those emails to another account I have rusticdog*xtra.co.nz (replacing * with @ of course
- wolfpup
Seem to have the same problem here.
All my plain text, subject line filters no longer work unless I change the filter from 'Subject' to 'entire message'
(Also seem to be having a startup problem - if Mailwasher starts with Windows all appears fine, however if I exit Mailwasher and try to restart from the Quick Launch toolbar the entire system freezes requiring a manual [power button] shut down - should I make this a different topic?)
- mr.den
OK, resent email this morning with filter screenie and header from email. (to your other email address)
- mr.den
For what it is worth, I created a new filter with only one rule in it, and it still does not work.
Been really buisy and have not had time to do this for a while
sorry for the delay.
- mr.den
OK, I did the same filter on another install on my laptop, and it works properly.
Can anyone point me in the right direction here, to isolate why the same filter on one install that used to work no longer works after updating to 1.0.27 but still works on my laptop after the same update? anything I should look for?
Please no generic "uninstall and reinstall" advice. There has to be a reason this is happening.
- mr.den
For what it is worth, installing 1.0.35 fixed the filter problem on the machine that was not working properly.
yeap great, sorry for not getting back to your properly....a little snowed under
let us know though if any problems crop up again
mr.den wrote:For what it is worth, installing 1.0.35 fixed the filter problem on the machine that was not working properly.
