about 50% of the time when right clicking on the icon in the sysem tray the MWP window just disappears into neverland and the icon in the taskbar has no effect.
the only solution found exit and restart MWP
not very handy ..
using WIN7
weird taskbar behaviour
- Sidewinder
- Weary Womble
Re: weird taskbar behaviour
Make sure you are not double clicking, the bottom entry on the Right Click menu is Close.
We think we'll have this sorted soon, there seems to be an issue with our borders at times. A quick interim solution might be to go into Settings >> Display >> and set MailWasher not to use Aero.
