gmail setup
Clingfree
gmail setup
Sat Oct 23, 2010 5:14 am
for some reason I can't get gmail to work with mailwasher pro, what's the proper setup procedure?
anniebrion
Re: gmail setup
Sat Oct 23, 2010 5:15 am
I use GMail via IMAP and just use the setup on the Google help pages.
Re: gmail setup
Sat Oct 23, 2010 7:48 am
I do the same but use POP and it is working like a champ.
http://forum.firetrust.com/viewtopic.ph ... 847#p17847
racker
Re: gmail setup
Sun Oct 24, 2010 9:05 am
Here a screen of my Gmailsettings... Succes!
My Gmailsettings.. Note the portnr..
Beta tester.. oh well! ;)..
MWP FAQ
Clingfree
Re: gmail setup
Mon Oct 25, 2010 4:22 am
i give up, nothing seems to work
Clingfree
Re: gmail setup
Mon Oct 25, 2010 5:02 am
well I did finally get the email on, but it doesn't stop email from going into gmail, before I can check it.
Re: gmail setup
Mon Oct 25, 2010 5:34 am
Clingfree wrote:well I did finally get the email on, but it doesn't stop email from going into gmail, before I can check it.
You need to look for two possible settings in your email program. First one is Send/Receive on start-up and Check Mail every (n) minutes. Turn them both off.
racker
Re: gmail setup
Mon Oct 25, 2010 6:22 am
Are you using webmail (http://mail.google.com/mail/) or do you use a E-mail client like Outlook, Thunderbird ao?
Please note:
- All mail, including spam, ALWAYS goes to your Gmail first.
- Normally you'd then either read it through webmail and/or download all via a client and delete the rubbish manually.
- What MailWasher does, is check your Gmailbox and delete any unwanted mail automaticly, so you will not have to do that yourself.
- Knowing this, you should make sure that MailWasher has "washed" out your Gmailbox before you either look at your mail through webmail or download it with a client..... Isse síímpel! ;)
MWP FAQ
