Windows Live v Mailwasher Pro 2011
ClaireV
Thu Jan 13, 2011 10:27 pm
Have just tried your new Mailwasher Pro - it doesn't clear mails from the list after I have washed the mail so I have to delete them manually (This is not good as I'm sure I'm going to delete one by accident). I'm using Windows 7. Can you help - or do I go back to my old and trusted version? In which case does anyone have the link to download it?! Thanks - Claire :(
racker
Re: Windows Live v Mailwasher Pro 2011
Thu Jan 13, 2011 11:05 pm
ClaireV wrote:Hi,
Hi Claire.. To begin with: unless you have un-installed it, the "old" MailWasher should still be on your system. MaillWasherPro 20xx is not an upgrade, but a new program. It does import the settings from its predecessor, but will not overwrite that; both programs can function perfectly beside each- other.
Then: MWP_20xx will clear the list automaticly upon a new check mail. If some "good" messages are still there, you should uncheck "leave a copy on server" in livemail:
EDIT: Just to be complete: do not forget to click the [APPLY] button after all this...
Succes!!
Beta tester.. oh well! ;)..
MWP FAQ
ClaireV
Fri Jan 14, 2011 2:32 am
Oh - no! Thanks for this. Clearly having a blonde moment! Sorted. Sorry!
