I had to do a bit of searching for my applications folder since I have iTunes on an external drive on my PC.
I found it in C:\\Documents and Settings\User\My Documents\My Music\iTunes\Mobile Applications.
The rest of my iTunes is, as I said, on an external drive in the program files\iTunes folder.
Folks who haven't done what I have can probably find the applications folder with the balance of their iTunes folders.
Location of Applications Folder
- cfheinz
- Guardian Gecko
Carl Heinz
- TrustFire
Re: Location of Applications Folder
Right, that location is possibly related to XP - it would be different on Windows 7 and Vista.cfheinz wrote:I found it in C:\\Documents and Settings\User\My Documents\My Music\iTunes\Mobile Applications
- cfheinz
- Guardian Gecko
Yup, I'm still using XP Pro. Too much legacy stuff probably won't work with Win7/8. Will probably have to bite the bullet some day, but, for now, XP works well for me. I've also gotten too lazy to go through the hassle of upgrading.
Carl Heinz
- cchur
- Active Albatross
Anyone have an idea of just where it would be in Vista? I am still looking for it.. Make sure I write it down when I find it...
Thanks for the help
Chuck Chur
Thanks for the help
Chuck Chur
Chuck Chur
Windows Vista SP2, Firefox 15 Beta currently, and Thunderbird 15. beta, iOS iPad beta
I RTFM and still can't dance
- TrustFire
C:\Users\YourUserName\Music\iTunes\Mobile Applications
Just guessing - I could be wrong, here.cchur wrote:Anyone have an idea of just where it would be in Vista? I am still looking for it.. Make sure I write it down when I find it...
Thanks for the help
Chuck Chur
- cchur
- Active Albatross
Found it, thanks! Took a lot of trial and error coordination,but I'm getting my training.
Chuck
Chuck
Chuck Chur
