White screen
hewiep
White screen
Sun Jul 22, 2012 5:09 am
MW was working on my iPad, now all I have is a completely white screen. Before I remove & reinstall, is there anything that you need or that I can do to get any info. All I have is a completely white screen with nothing visible. Everything else is working fine.
cchur
Re: White screen
Sun Jul 22, 2012 8:02 am
I have the same problem right now. I have Version 0.0.3 that has been running for a long time (since it was released to beta) and this happened before when the server had problems. I guess we just wait. Should not be long as they are parity much on top of things.
Chuck
Chuck Chur
Windows Vista SP2, Firefox 15 Beta currently, and Thunderbird 15. beta, iOS iPad beta
I RTFM and still can't dance
Re: White screen
Sun Jul 22, 2012 8:05 am
Sorry, looks like server issues somehow. I'll get the developer to investigate.
cchur
Re: White screen
Sun Jul 22, 2012 10:52 am
Up and working fine now.
Chuck Chur
B.Lhester
Re: White screen
Sun Jan 13, 2013 11:27 pm
I encountered this once and then it worked after I restarted the device. Is that normal?
Re: White screen
Mon Jan 14, 2013 9:37 am
No, it shouldn't happen but we've changed quite a few things so it shouldn't happen in the next version when we release that soon.
Mbettyarantt
Re: White screen
Sun Mar 10, 2013 5:13 pm
nick.bolton wrote:No, it shouldn't happen but we've changed quite a few things so it shouldn't happen in the next version when we release that soon.
Hi Nick! When would that be? I don't know if it's my device or is it the app that has the trouble. Dropped my iPad and then white screen on the app happened after a few days.
"The power of imagination makes us infinite." valuepointdistribution.com reviews
Re: White screen
Sun Mar 10, 2013 6:06 pm
Here's an updated version which fixes the whitescreen
Android
http://cdn.firetrust.com/apps/mailwashe ... screen.apk
iPhone/iPad
http://cdn.firetrust.com/apps/mailwashe ... eenfix.ipa
Re: White screen
Mon Mar 11, 2013 12:27 am
New patch working fine on the iPad. :thumbsup :thumbsup :bow
I brought my iPad out of sleep this morning and went to MWM and the error message appeared and then the Start button appeared. On the second attempt at Start all is up and AOK for this problem
