For the moment, i have a Samsung Galaxy Tab 1 10.1, Android 4.0.4.
MailWasher Pro Mobile Android = did can be tested soon?
At my side i can test on android, ...
MailWasher Android version, did can be tested soon?
- SSTSylvain
- Modérateur française
SSTSylvain
- michaelkenward
- Guardian Gecko
Re: Android version, did can be tested soon?
Me too.
Asus Nexus 7 here. And Acer E320.
Filled in android appli
MK
Yeah the Android version is never far behind.
The next beta currently set for release next week will be both IOS and Android versions
- michaelkenward
- Guardian Gecko
Got it. Installed it. But the single account limit means that I can't do much to test it.
I'll look for the spammiest account and throw it at that.
MK
- SSTSylvain
Did i miss the url "Mobile MailWasher Android download link" ?
michaelkenward wrote:Got it. Installed it. But the single account limit means that I can't do much to test it.
SSTSylvain
I don't know the download link either
Though I would wait for the next version any way, plus if we have the new beta of MailWasher Pro working right as well, it should be fairly painless to setup
- michaelkenward
- Guardian Gecko
Re: MailWasher Android version, did can be tested soon?
MK
- michaelkenward
- Guardian Gecko
Now I just have to work out how to delete the account I have set up so that I can change it to another one. But that is probably something to chew over on the beta site.
The software is clearly work in progress.
MK
- smart1960
Can someone put the link up again please for this (version 0.4 I think is the latest) as I can't find any links to a download link when I go to the page to get it from? Muchas gracias amigos..
- SSTSylvain
v0.04
http://cdn.firetrust.com/apps/mailwasher/Android/MailWasher-Android-0.04.apk
smart1960 wrote:Can someone put the link up again please for this (version 0.4 I think is the latest) as I can't find any links to a download link when I go to the page to get it from? Muchas gracias amigos..![]()
v0.04
SSTSylvain
