MailWasher Android version, testing results
SSTSylvain
Modérateur française
Sat Sep 01, 2012 2:47 am
MailWasher v0.02 for Android.
Samsung Galaxy Tab 1 10.01 Tablet, Android 3.2
The software close when i try to press the button "save" email pop configuration. After, when i return into MailWasher v0.02 for Android. = it dont have keep the parameters, before closing.
SSTSylvain
SSTSylvain
Re: MailWasher Android version, testing results
Sat Sep 08, 2012 2:56 pm
Samsung Galaxy Tab 1 10.01 Tablet, Android v4.0.4
After updating from Android v3.2 to Android v4.0.4, the MailWasher v0.02 software for Android dont make "lock error, close error".
SSTSylvain
SSTSylvain
Sat Sep 08, 2012 2:58 pm
Did others people can test MailWasher Android version ?
Did i am the only one that test, ... ?
SSTSylvain
smart1960
Sat Sep 08, 2012 9:11 pm
Nope. I will be testing when Nick brings the next version on line mate. Hope it won't be to long and I have a feeling we are going to have a good prog when all said and done. I am sure Nick will give us a shout when the next version is ready to play with? :lol:
SSTSylvain
Mon Sep 17, 2012 1:42 pm
Did it will be an landscape version? For the moment, is only in portrait.
SSTSylvain
Mon Sep 17, 2012 10:34 pm
Yes, we'll have it in both portrait and lanscape, just needed to work out some problems with it so it's not in this version. We'll have a slightly more usable interface for tablets as well.
diogenes
Wed Sep 19, 2012 6:01 pm
On Android Galaxy Nexus MW 0.0.4 does not remove "zombies".
Neither "check" nor "wash" removes emails from the local device list that have been removed from the email server by another client.
Ralph E Kenyon Jr - Philosopher
Retired Navy, former IT consultant and programmer, now retired.
http://www.xenodochy.org
diogenes
Wed Sep 19, 2012 6:12 pm
on Android Galaxy Nexus MW v 0.0.4 does not change the header.
1. Press the tools icon.
note v0.0.4
2. Press Email accounts.
note v0.0.4 does not change to "Add Account"
3. Watching carefully, tap the first email account.
note that "Add Account" flashes briefly, then changes to "Delete".
This indicates that the "display 'Add Account' " instruction is misplaced in the code to a point after the instruction to display the email accounts.
4. tap "back"
note that the display now correctly reads "Add Account".
diogenes
Wed Sep 19, 2012 6:35 pm
Android Galaxy Nexus MW v0.0.4.
1 I systematically deleted all the zombies mentioned previously by marking the trash bucket and pressing "Wash".
2. I shut down mailwasher by pressing the system previous or back button until I got to back to my wallpaper.
3. I clicked the home key.
4. I clicked on the multitask button and dismissed Mailwasher from the list.
5. I exited the multitask screen - back to the home screen.
6. I pressed the Mailwasher icon.
Mailwasher came up with all the deleted zombies back in the list.
I retried with only one washed out, it came back with the check mark, then I dismissed MW again and restarted it. Then the marked zombie disappeared.
Wed Sep 19, 2012 7:51 pm
Thanks for the report Ralph, we'll investigate those. I"ll contact you about the zombies, and see if we can get a test account setup
SSTSylvain
Wed Sep 26, 2012 10:14 am
For the moment MailWasher Android v0.04 = Stable without bug errors. :thumbsup
I still wait for new release(s) and rusticdog, ... and stable MailWasher Android server, without loose parameters and options.
Keep up on the good work, ... :thumbsup :bow :bow :thumbsup
SSTSylvain
diogenes
Tue Oct 09, 2012 12:57 pm
Android Galaxy Nexus. Cannot create email account.
Entering my email account failed with message "Alert Device not known" after pressing "Save".
Tue Oct 09, 2012 12:59 pm
Just sending a new version to you all. Give me 5 minutes ;)
diogenes
Tue Oct 09, 2012 3:48 pm
I installed four email accounts.
lost:
1. The option to display all accounts together, that was in .04 is missing in .05.
"bug":
2. When entering an email address, I got a pop-up with a saved email address, but it was misplaced, mostly covering up the text being entered, making it very difficult to edit the inserted text. The pop-up with the previously saved info needs to be relocated so it does not cover the underlying text window being entered/edited, or it needs to be turned off after it is used to insert the text, or there needs to be a way of dismissing the suggested text window.
Nice to have
It would also be nice if the domain part of the email address were loaded into the server email address and the name portion of the email address loaded into the user name when a new email address is first entered.
I'm looking forward to filters.
jahnr
Tue Oct 09, 2012 6:50 pm
the new MW version 2012 1.21.0 allows 'sync to mobile'
The Syncing login asks for a Username/Password
Q: to which account does this function refer ?? Please explain
thanks in advance / Danke
Robert
Mailwasher Pro [v7.1.0] ― Mailwasher Mobile [v1.2]
