pop ok - no imap available.
RayHerring
Mon Sep 17, 2012 2:14 pm
Motorola Xoom 4G on Verizon running ICS.
My pop account created successfully. Operation is perfect so far.
My one Imap account could not be created.
No SSL available to select for security on the pop account but it accepted port 995 for the SSL layer and downloaded all the email. We'll need a selection to be able to delete mail from server or not.
For a 0.4 iteration, I think it's stupendous! Good work and pats on the back to all!
Ray
RayHerring
Re: pop ok - no imap available.
Mon Sep 17, 2012 3:30 pm
One thing I forgot, MW needs to be able to operate in landscape for tablets (Xoom) and the RAZR when they are located in their respective docks. Have to take out of the dock when using. Minor stuff for better convenience.
Ray
michaelkenward
Guardian Gecko
Mon Sep 17, 2012 8:52 pm
RayHerring wrote:My pop account created successfully. Operation is perfect so far.
Nothing works here. Completely dead. Cannot add POP accounts. (See other message.)
Any suggestions on what to do to make it work?
Did you do anything other than simply install the program?
MK
Mon Sep 17, 2012 10:32 pm
Thanks Ray
Yes, IMAP not supported but intrigued you got it working with SSL just by choosing port 995.
Landscape mode will be supported but we ran in to some difficulties, anyhow we'll have a slightly modified and more usable GUI for tablets.
And for the bad news. Looks like it's gone offline. Will need senior developer to look at this and unfortunately it's really late here so we'll get this working again in the morning. Of course when it's in final release we'll have it people to monitor it 24/7 (and what ever caused this to go offline - fixed)
RayHerring
Tue Oct 09, 2012 4:38 pm
Nick,
Installed 05, works fine on the Xoom. Will try the RAZR tomorrow. And the SSL here on the Xoom. I don't think I could get it to work a second time on 04. Might just have been a fluke, but will see anyway. On edit. I see the port is greyed out anyway so can't try that... Darn... LOL
Ray
Tue Oct 09, 2012 5:07 pm
Yes, we switched off SSL ports for this version just so it wouldn't make us hunt down errors we're not supporting.
RayHerring
Tue Oct 09, 2012 5:27 pm
Installed on the RAZR, picked up everything I had installed on the Xoom just fine. Email address was there after I logged in.
