Mailwasher on Dell Streak 7
rdtecs
Thu Sep 20, 2012 2:02 pm
The application loads and all seems well, but it will not accept a numeral 9 in the password field. Is this a know problem?
PS Works fine if the numeric does not contain a nine. Thanks
Re: Mailwasher on Dell Streak 7
Mon Sep 24, 2012 12:19 pm
Are you using the latest version 0.4?
http://cdn.firetrust.com/apps/mailwashe ... d-0.04.apk
Does the number 9 just not work when you enter it? ie nothing is displayed? Or does it crash the app?
