problem syncing from pc to iPad
filterboy1
Tue Nov 06, 2012 1:47 pm
installed new desktop version and checked "include account for syncing"
I also installed the latest version of the iPad version.
Clicked " sync to mobile" and received "syncing login" screen.
What username is it looking for? Tried the account login but that did not work.
Is it the mobile login? if so, I don't recall providing it. How would I retrieve it?
Thanks,
Fred
anniebrion
Re: problem syncing from pc to iPad
Tue Nov 06, 2012 11:26 pm
Have you created an account in the iPad app? This is the username and password you use in the Desktop client for syncing.
Annie.......... PC details (see Web Server) - link only available between 9am and 10pm (UK)
Mailwasher Pro βeta [v 7.12.6]
filterboy1
Wed Nov 07, 2012 4:31 am
I must have created an account because I see a logout function. But I don' t know what it is. How can I retrieve it?
Can I create another one?
Fred
filterboy1
Wed Nov 07, 2012 9:30 am
I read a post by Nick that I could create another account on the iPad by just putting a 1 in front of the email address when creating an account. It worked. I was then able to try a sync from the laptop. It took the login and password but failed with "error connecting to cloud server"'.
Found post saying delete cloud.dat file and try again. I closed mwpro and deleted the file. Started mwpro again but got the same msg.
What is my next step to resolve this?
thanks,
fred
Fri Nov 09, 2012 11:06 am
Hi Fred
I'm a bit perplexed by this one, but it may be that you have duplicate accounts setup somehow. If you can let me know the email address you used (feel free to send me an email at nick.bolton@firetrust.com) and we'll delete the accounts so you can start again.
Nick
filterboy1
Wed Nov 14, 2012 1:13 pm
Nick,
I added an account again mw on the mobile after you deleted the accounts. I am how seeing my email again on the mw mobile.
I went to mw desktop and clicked on sync mobile. I was expecting to see it prompt me for the new user & password but it did not. I them got error message - can't connect to server. How can I get the user/password prompt to use the new user/password.
Thanks,
Fred
Wed Nov 14, 2012 1:21 pm
In MailWasher Pro 2012, go to Help>>User Files. Shut down MailWasher
(File>>Exit). Then in the User Files open window, delete the cloud.dat file.
Restart MailWasher.
In Settings>>Accounts, press the 'Sync to mobile' button.
filterboy1
Wed Nov 14, 2012 1:38 pm
thanks, it now does not give the error when I sync, now ever when I look at the lists on mw mobile, I don't see the items from the desktop. Is there some time delay?
thanks,
Fred
Wed Nov 14, 2012 2:16 pm
It's only meant to sync the account settings, not the actual emails. There is a delay at the moment in checking the emails in the background.
Also, you need to select which email accounts are to be sync'd.
Go to Settings>>Accounts. For each account, check the box
'Include this account when syncing' for those accounts you want to sync to
the mobile version.
Click the 'Sync to mobile' button. This will prompt you to create an account
or sync your already created account.
filterboy1
Sat Nov 17, 2012 6:17 am
I have done all the steps you have described.
I was expecting to see the entries in the friends & blacklist lists on mw desktop to be in the spam list on the mw mobile.
But I do not see them, only the ones I added via the mw mobile?
Fred
Sat Nov 17, 2012 6:19 am
Sure, that feature is not in there yet but it's coming very soon.
Nick
filterboy1
Sat Nov 17, 2012 6:27 am
Hi Nick,
Thanks for clarifying, I don't want to be testing features that are not yet :)
