Beta Version .08 install.
RayHerring
Tue Dec 11, 2012 5:28 pm
Installed version .08 and did the sync with the desktop and worked perfectly. No problems noted at all so far. Seems to be coming along very nicely!
Ray
daveadams
Re: Beta Version .08 install.
Wed Dec 12, 2012 12:23 am
Hi Nick,
Echoing Ray's post, installed 0.08, only problem I had was getting used to iTunes 11. Otherwise the app working with no problem so far, great to be able to check emails and delete when out and about with confidence again.
iPhone 5S IOS 8.1.2 (Not Jailbroken)
Samsung Galaxy Tab2, Android Version 4.0.4
Windows 7 Ultimate 64bit Laptop
Mail Washer Pro 2012 7.4.1
Mail Washer Mobile 2.0.0
anniebrion
Wed Dec 12, 2012 12:54 am
No issues with the upgrade here, so far :devil
Annie.......... PC details (see Web Server) - link only available between 9am and 10pm (UK)
Mailwasher Pro βeta [v 7.12.6]
Wed Dec 12, 2012 1:33 pm
Yes, iTunes 11 is a bit difficult to describe how to get around it.
michaelkenward
Guardian Gecko
Wed Dec 12, 2012 11:00 pm
I found out about the new beta version while I was on the road yesterday. I discovered that MW Mobile would not work. It just flashed a message at me about the new version.
Would it be possible to provide a link in the alert that would take me to the download file?
I know I could do that with my browser, but that means messing around a lot. (I didn't bother.)
I realise too that eventually the updates will probably come from Google Play. But we don't know how many more betas there will be before that happens.
On the new version – and the old ones – I would still like to see a "rotating" version that would work in landscape mode. Very few of my android apps work only in portrait mode.
MK
Thu Dec 13, 2012 5:10 am
Hi Michael
Not too many more betas before we do the first release, so it will be fairly basic to begin with. Not sure if we can do a link in the error message since there's IOS and Android versions, so we'd have to do a check but I'd rather spend time on adding other features we need to get finished, including landscape mode :)
michaelkenward
Guardian Gecko
Thu Dec 13, 2012 7:43 am
Fine by me. Landscape is more important than the other trinkets.
MK
