Version 9
Version 9
Tue Jan 22, 2013 3:20 pm
D/L the file, put it in Itunes and the app indicated Update. Did the apply and all is good. :thumbsup :thumbsup
Horizontal display looks good here on IP4G
Re: Version 9
Tue Jan 22, 2013 3:25 pm
Message time stamp problem resolved.
Re: Version 9
Tue Jan 22, 2013 3:32 pm
Good :)
There's a few horizontal display issues to fix with Android version, but IOS is fine, aside from the login screen for both.
Re: Version 9
Wed Jan 23, 2013 1:38 am
Blacklist sync worked, including wildcards.
Re: Version 9
Wed Jan 23, 2013 1:46 am
In my morning sync I had a spam message and it was highlighted in pink as it should have been but I don't think the Delete check mark was there. I'll watch for another later.
Re: Version 9
Wed Jan 23, 2013 2:05 am
Time stamp problem is not solved. Message in the grid now showing 8:34 PM today and it is only 8:04 AM. MWP shows it should be 7:34 AM.
Next message in shows 8:02 AM which is consistent with the Sent time in MWP.
I suggest that you change to the time received rather than sent.
There have been numerous problems with bad Sent times in MWP.
Re: Version 9
Wed Jan 23, 2013 4:21 am
A message came in shown in pink but the Delete check mark was missing again. I opened the message and declared the sender as a Friend, the message then went from pink to green but the delete check mark then showed.
stmiranda
Re: Version 9
Sat Feb 09, 2013 6:47 pm
Seems MWM on my Android is no longer retrieving email. Tried logging out and back in. Anything I can do to further troubleshoot?
Re: Version 9
Sun Feb 10, 2013 6:35 am
stmiranda wrote:Seems MWM on my Android is no longer retrieving email. Tried logging out and back in. Anything I can do to further troubleshoot?
FT servers were taken down, likely due to a DOS attack. Servers are back up but this problem also affected me on my IPad. Working with FT for a solution.
Re: Version 9
Sun Feb 10, 2013 8:44 am
Looks like there's problem with checking SSL accounts since the outage, plus an error with adding new SSL accounts, so we'll take a look and get this fixed.
Re: Version 9
Mon Feb 11, 2013 6:35 am
BUG? - Domain Blacklist not being observed with wildcard entry. I have multiple domains blacklisted with wildcard entries that are functional in MWP. Just checked a message in MWM and it was not marked as spam. Entry confirmed as *@*.co incoming message was From: Ava ([email protected]) In MWM and "Ava" <[email protected]> in MWP. MWP properly flagged it.
Re: Version 9
Mon Feb 11, 2013 9:54 am
Yes, MWM doesn't support Wildcards yet, but we've got it on our list to do.
