Have just downloaded mmm so far great. Q are you able to go to your email app from mmm or do you close mmm open other?
Does mmm remove washed mails from server?
mmm
- Sidewinder
- Weary Womble
Re: mmm
MWM removes the mails with the check mark from the server when you do a wash.
MWM doesn't start the email app at this time, you don't need to close MWM. Remember to change the email application to only check for new mail manually.
- kerillhxavier
Re: mmm
I see. So that is why I got some mails missing after the wash.Sidewinder wrote:MWM removes the mails with the check mark from the server when you do a wash.
