Problems logging in
hansi
Problems logging in
Wed Mar 20, 2013 9:59 pm
I have just downloaded the mobile app onto my phone but I cannot seem to be able to log in using my user name and password. I've tried all combinations but nothing works. Is is the same details as on my desktop MW programme?
Re: Problems logging in
Wed Mar 20, 2013 11:54 pm
Yes the same log on info is used at both the Desktop version and the phone version.
What error message are you getting?
Are you running Droid or IOS?
hansi
Thu Mar 21, 2013 12:21 am
Message says incorrect user and password. Using Android 2.1 update 1
Thu Mar 21, 2013 12:31 am
What version of MailWasher Pro are you using?
Did you create the Mobile Account in MWP Sync?
Also note there is a new version of MWP posted in the forum. Best to update to it first.
hansi
Thu Mar 21, 2013 12:44 am
1. The new version downloaded today.
2.No, how do I do that?
3. I have the latest version.
hansi
Thu Mar 21, 2013 12:50 am
I found the sync, but it still says wrong user and password. Is it the password entered into my email account the one I should use, the one I use in MW? Otherwise, how can I find out what my password and usser name is.
Thu Mar 21, 2013 1:22 am
hansi wrote:I found the sync, but it still says wrong user and password. Is it the password entered into my email account the one I should use, the one I use in MW? Otherwise, how can I find out what my password and usser name is.
No it is not your email account (unless you have set it up that way).
Either on MWP Sync or your phone there should be a Create function where the Log In is.
Once you Create an Account then you log in from either place.
In MWP Sync once you log in after setting up the mobile account you can then Sync your settings from MWP to MWM.
hansi
Thu Mar 21, 2013 6:31 am
I managed to sync on the MW site on my desktop, but when I tried to open on my phone, it gave the same error mesage. Thanks for your help, I've given up on it now.
Sat Mar 23, 2013 12:29 pm
Sorry for the late reply, please don't use a username with email address or space in it when setting up in MailWasher Pro. I can delete it for you and you can start again if you let me know the username you used.
Nick
hansi
Sat Mar 30, 2013 7:42 am
I've got a new phone now with up to date software and I tried to log in again. Got in ok, but it says I need to upgrade to the latest version of MW Mobile. I thought it would have been the latest version from Google Play?
Sat Mar 30, 2013 7:47 am
Sorry about this, we put a few more servers online yesterday and some people started getting this message. We'll have it fixed shortly. There's no newer version needed.
hansi
Sat Mar 30, 2013 7:50 am
Thank you
Sat Mar 30, 2013 8:53 am
Should be working again ok now
hansi
Sat Mar 30, 2013 6:45 pm
yes, all ok now. Thanks.
