Hi All
How the heck do I create a 'Mailwasher ID' to use with this app ?
When I try to do it through Mailwasher Pro on my PC I get an 'email address already in use' error and errors if I use the app. to create an ID
Mailwasher ID ??
- racker
- Knowledgeable Kea
On your PC, in MWP, go to settings>>sync (log out if necessary) and create a new account, using an other E-mail address.
After successfully going through the process,
open the app on your phone and log in to the account you just crerated on the PC (do NOT attempt to crerate the account again!!)
That's it.. now just sync all settings from the PC to the phone..
Re: Mailwasher ID ??
Assuming yo aren't logged in, you could try and create a new account, using another E-mail address for the login (at this moment it's only used as identification); do the following:madaxeman wrote:Hi All
Beta tester.. oh well! ..
MWP FAQ
MWP FAQ
- nick.bolton
- The Big Cheese
Hi, if you're having problems I can delete your account so you can start again (just send me your username you signed up with), but please don't use an email address or username with a space in it for your Mailwasher ID as we've not learned that these can be created in MW Pro, but not used in MW Mobile.
Nick
Nick
- chloejennor
I think this is the trouble I got.
nick.bolton wrote:Hi, if you're having problems I can delete your account so you can start again (just send me your username you signed up with), but please don't use an email address or username with a space in it for your Mailwasher ID as we've not learned that these can be created in MW Pro, but not used in MW Mobile.
Nick
"The healthiest response to life is joy." choosehottubsdirect
- nick.bolton
- The Big Cheese
Ok, send me your details to nick.bolton@firetrust.com and I'll reset everything
- philr
It's odd because it has been working fine. If I e-mail you my username (as well as the two I created to try and fix it) could you please delete them so that I can start again?
Any suggestions as to a fix other than the above would also be welcome.
I'm having a problem with the Android app too. It won't let me log in, I just repeatedly get 'Incorrect User name or Password'. I've tried resetting the password both from the PC version and the mobile one (my user name logs in correctly on the PC), but the mobile app is not recognising it. I've even tried to create a new username (twice) with no joy.nick.bolton wrote:Hi, if you're having problems I can delete your account so you can start again (just send me your username you signed up with), but please don't use an email address or username with a space in it for your Mailwasher ID as we've not learned that these can be created in MW Pro, but not used in MW Mobile.
Nick
- nick.bolton
- The Big Cheese
We've got a few people reporting this problem, we're looking at it, but please send me your user ID's
- nick.bolton
- The Big Cheese
This problem has been resolved now so you should be able to login normally again
- philr
Working as expected now, thanks.nick.bolton wrote:This problem has been resolved now so you should be able to login normally again
