BUG: some addresses cannot be deleted from MWM blacklist
- racker
- Knowledgeable Kea
Just found out, that it's impossible to edit or delete addresses, beginning with *@* (f/i *@*nonexisting.com) in MWM's blacklist..
(MWM Android)...
Beta tester.. oh well!
MWP FAQ
MWP FAQ
- nick.bolton
- The Big Cheese
Re: BUG: some addresses cannot be deleted from MWM blacklist
Ok, we're not actually supporting wildcards yet, but obviously you should be able to edit/delete them. Noted, and we'll get it fixed. Have a new version out for testing next week with lots of speed improvements, 'unable to connect to server' fixed, notifications and other stuff
- nick.bolton
- The Big Cheese
Strange, I can delete them ok, although I'm doing it via browser (since I don't have an Android or IOS phone with me at home here)
Do you want to try this version http://cdn.firetrust.com/apps/mailwashe ... er-101.apk as it updates the framework we're using and speeds things up and fixes some other GUI bugs.
- racker
- Knowledgeable Kea
Just installed your new version: no go... added two more (fake) *@* addresses: *@*xxopvuladres and *@*blubberbuik.com and guess what... Now I'm stuck with three b/l entries that cannot be deleted!
MWP FAQ
MWP FAQ
- Sidewinder
- Weary Womble
Do you have Sync enabled in MWP?racker wrote:Just installed your new version: no go... added two more (fake) *@* addresses: *@*xxopvuladres and *@*blubberbuik.com and guess what... Now I'm stuck with three b/l entries that cannot be deleted!
- racker
- Knowledgeable Kea
Yep... but disabling/enabling/syncing/editing w/o sync... no difference: as soon as I enter any (fake) address beginning with *@* in MWM android, I can neither edit, nor delete that entry.Sidewinder wrote:Do you have Sync enabled in MWP?racker wrote:Just installed your new version: no go... added two more (fake) *@* addresses: *@*xxopvuladres and *@*blubberbuik.com and guess what... Now I'm stuck with three b/l entries that cannot be deleted!
MWP FAQ
MWP FAQ
- Sidewinder
- Weary Womble
Maybe as Nick said "Wild Cards Not Supported Yet" as in they don't exist.racker wrote:Yep... but disabling/enabling/syncing/editing w/o sync... no difference: as soon as I enter any (fake) address beginning with *@* in MWM android, I can neither edit, nor delete that entry.
