Logged in as: showed "undefined" until I logged out and in again; now displays my inlog-name
Switching from "ALL" to a single account went OK, but switching back to "ALL" froze the app, android reported it to use 30% resources..
BIB Same here.racker wrote:Installed over previous version OK![]()
Logged in as: showed "undefined" until I logged out and in again; now displays my inlog-name![]()
Switching from "ALL" to a single account went OK, but switching back to "ALL" froze the app, android reported it to use 30% resources..![]()
After killing MWM in task manager and restarting all works OK; could not repeat the freeze. Will keep an eye on that..
On the iPad go to Setting (App) >> Notifications >> Mailwasher and turn off there.mrgou wrote:Reverted to 1.1, problem solved.
Also, before I did this, I noticed that, with 1.2, I started getting notifications when new mail arrived. Nice idea, but I didn't want those and couldn't find a way to disable them. Maybe I missed it, but if not, please note that it should always be possible to disable notifications.
Carl instead of trying to open the file can you highlight the link and chose download?cfheinz wrote:I get the following error message when trying to download the provisions file using Internet Explorer:
The XML page cannot be displayed
Cannot view XML input using style sheet. Please correct the error and then click the Refresh button, or try again later.
An invalid character was found in text content. Error processing resource 'http://cdn.firetrust.com/apps/mailwasher/IOS/1.2..
Tried to find something similar on my Android phone: no way to change sync settings and/or notifications...anniebrion wrote:On the iPad go to Setting (App) >> Notifications >> Mailwasher and turn off there.mrgou wrote:Reverted to 1.1, problem solved.
I tried that. I even tried opeining it in Mozzilla.Sidewinder wrote:Carl instead of trying to open the file can you highlight the link and chose download?cfheinz wrote:I get the following error message when trying to download the provisions file using Internet Explorer:
Go to the new topic for 1.2 at the top of this forum and scroll down to the link for the file and then right click. Choose "Save target as" rather than open it will work in either IE or FF.cfheinz wrote:I tried that. I even tried opeining it in Mozzilla.Sidewinder wrote:Carl instead of trying to open the file can you highlight the link and chose download?cfheinz wrote:I get the following error message when trying to download the provisions file using Internet Explorer:
