V1.2 Beta Update
V1.2 Beta Update
Wed Jul 17, 2013 12:06 am
Installed here on IPad.
There is a problem with trying to download the provisions file in IE. All it would do is open a blank page. Firefox had no problem. I have IE set as default but use FF for all casual browsing.
Re: V1.2 Beta Update
Wed Jul 17, 2013 3:58 am
1) What's new in version 1.2
Confirmed:
* Trash bin
* Source view in email preview
* Notifications for new email, can be set per account
Not seen for IOS:??????
* Now shows: Logged in as 'user' - User Name Still shown
* Improved friendslist and blacklist icons??????????
cfheinz
Guardian Gecko
Wed Jul 17, 2013 4:07 am
I also had to use Firefox to get the provisioning file.
Carl Heinz
Wed Jul 17, 2013 9:32 am
1. Go to bottom of settings page
2. They're just a bit different to remove the ambiguity with the plus and minus signs on them.
Wed Jul 17, 2013 10:57 am
My bad on Item 1. Thought that had already been there.
On Item 2, never use the l/r swipe so didn't observer the difference. Works for me.
Bodger49
Fri Jul 19, 2013 7:13 am
Since the last update (yesterday) I keep getting an alert sound indicating new messages received. I have gone through each individual email setting within android mailwasher and unticked the " Notifications for new email" but the alert keeps sounding
I have saved each change and returned to each email setting to ensure the tick is still removed.
This is very annoying. How do I stop it.
Bodger49
Fri Jul 19, 2013 9:16 am
I have another user experiencing this also. Which version of Android are you using?
Bodger49
Fri Jul 19, 2013 9:27 am
Version 4.0.4
edited to add:- Alert sound is the same as when a text message is received
stmiranda
Fri Jul 19, 2013 10:02 am
Add me to the list of folks getting the alert but nothing showing up. I'm on the Galaxy S3 with 4.1.2.
I'm also still getting a sold white page when I launch the app. Tapping anywhere on the screen then shows the navigation bar.
In addition, the back button does not work after selecting an email. Have to use the phones back key. Syncing is painfully slow and prior to this post I was getting everyone's favorite, "unable to connect to server".
stmiranda
Fri Jul 19, 2013 11:13 am
Thanks, a couple of other users have found this to be an issue as well, so we're trying to replicate it here. I'll update you when we have a fix.
cfheinz
Guardian Gecko
Fri Jul 19, 2013 1:03 pm
The number of new messages doesn't agree with the number in the "New Messages" message. I've had some instances of the message appearing with the "No Email".
Fri Jul 19, 2013 1:59 pm
Ok, the notifications problem for Android is now fixed - no need to download a new version. We're looking at some other efficiencies if you're seeing any slowness.
@ cfheniz - the notification shows an aggregate of all your email accounts, so maybe you're looking at the wrong account?
cfheinz
Guardian Gecko
Sat Jul 20, 2013 6:49 am
I don't think so. I've got Safari set to all inboxes, and I've only set up my single Charter account in MWM.
Carl Heinz
Sat Jul 20, 2013 7:07 am
If you click on the notification, it should download and display the new notified email, if you just go to the app, can you try and pull down to see if that brings in new email?
