I've used Mailwasher for a few years now and was really pleased when you brought out the mobile versions.
These have worked fine for months but stopped working today on both devices saying I had no mail accounts set up on them?
I tried deleting the apps and downloading again but when I try to login it says my username and/or password is incorrect. I looked up my username in the MW Destop App in Sync settings, so I know my user name is right, and even asked to reset the password but when I used that to try and login, the apps still said my username and/or password is incorrect.
What can I do to get this working again?
Thanks,
Mike
Problems with MWM for iphone 5 and ipad 2
- racker
- Knowledgeable Kea
Re: Problems with MWM for iphone 5 and ipad 2
Have you logged in w/i the last couple of weeks? Looks like the same problem I had: http://forum.firetrust.com/viewtopic.php?f=55&t=14163
I suggest, re- creating your account with exactly the same credentials and syncing from your desktop (worked for me)...
Beta tester.. oh well!
MWP FAQ
MWP FAQ
- mike.dickman
Thanks for the reply.
Didn't get a chance to try your solution as there was an App update yesterday which seems to have resolved the problem on both devices.
Thanks for your help though.
Mike
Mike
- nick.bolton
- The Big Cheese
Yes, sorry about that. We had a faulty server update at the time.
- raydenuduff
This worked for me. Thanks!racker wrote:Have you logged in w/i the last couple of weeks? Looks like the same problem I had: http://forum.firetrust.com/viewtopic.php?f=55&t=14163
