No internet connection found on MW Mobile
mullock
Thu Jan 09, 2014 1:33 pm
My Mailwasher Mobile has only intermittently operated recently and gives the error message "No internet connection found" when there is both a wireless and cellular connection available.
Re: No internet connection found on MW Mobile
Thu Jan 09, 2014 2:21 pm
What phone are you using? This error is the phone telling Mailwasher that there's no internet connection. Have you tried restarting your phone?
mullock
Thu Jan 09, 2014 3:40 pm
It is the iPhone 4S and the phone and app have been restarted many times.
Thu Jan 09, 2014 4:35 pm
Ok, can you browse the internet etc just fine on the 4S? How long ago did this start happening?
Can you also try going to https://node.mailwasher.me on the iPhone browser and see if that works ok?
Fri Jan 10, 2014 3:58 am
Security app etc. blocking access?
mullock
Fri Jan 10, 2014 5:37 am
This has been happening on and off for the last month or so. It usually works on Wi-Fi but not always.
It works fine by going to https://node.mailwashser.me but won't work by going to the apps url.
Fri Jan 10, 2014 9:35 am
Ok, thanks. That points us a problem with the 'wrapper' that we use with the app. The app is actually just a website (the node.mailwasher.me link) but we wrap it up to make it look like an app and it communicates with the iPhone's internals. Are you using the latest IOS 7 updates or still on IOS 6? Strange only you're seeing it as no one else has reported this.
Fri Jan 10, 2014 10:26 am
Any other devices swamping the WI FI on phone or external?
mullock
Fri Jan 10, 2014 12:14 pm
IOS 7.0.2
mullock
Fri Jan 10, 2014 3:16 pm
I deleted and reinstalled MW mobile and it is working fine on WiFi but the same problem of "No Internet connection" with cellular.
Fri Jan 10, 2014 3:43 pm
Ok, it's pretty hard for us to guess at what's going on there if we can't replicate it here ourselves and if no one else is reporting the issue. We are rewriting the app at the moment, so will update a lot of the components, but it still doesn't explain what's going on with your issue. So, at this point we're still in the dark...
mullock
Wed Jan 15, 2014 10:17 am
Some things are so simple in hindsight.
Of all the many apps on my iPhone the only one that had cellular data turned off in settings was Mailwasher.
Thanks so much for your superb support and a great product Nick.
Wed Jan 15, 2014 10:57 am
Great, thanks for letting us know.
