POP3 email settings are incorrect
tosch
Tue May 27, 2014 11:38 pm
I keep gettting the error 'Your POP3 email settings are incorrect, please fix.'
I'm sure I have entered the correct details.
What could be wrong?
Incoming: pop.mail.hostpoint.ch
Port: 995 / SSL
Tom
Re: POP3 email settings are incorrect
Wed May 28, 2014 3:47 am
First is your account at hostpoint set up as IMAP or POP?
If POP then double check that you don't have an extra space either at the front or back of your entries and that your User info is correct.
tosch
Wed May 28, 2014 7:52 pm
problem solved, my bad
