Greetings,
I'm new to the iphone but have used MailWasher Pro on a pc for years.
New IPhone 5C 8.0.2
App : fresh dpownload and install of mailwasher from ITune App Store.
Create account : very very frustrating email address entered, user name enter, password entered -> Create mailwasher ID/ The spinning circle displays for a few seconds and the nothing. No notification of account created, no error notifications, just a back button
Login does not accept the data entered.
Any ideas would be very much appreciated before I throw the whole thing in the trash can. -David
Create Account Problem
- David Bethel
- Sidewinder
- Weary Womble
Re: Create Account Problem
Nick will respond but if you are in fact a new iOS MWM user then the problem most likely due to Apple's restrictions on Beta software testing. Your device ID must be registered as an authorized user or it will not work.
- David Bethel
- nick.bolton
- The Big Cheese
- David Bethel
Thanks~! So far so good
Now if I can find a way to do an install without using the horrible iphone key board. Tom Tom gives you that option when the unit is connected to a USB port
So far I have figured out how to rearrange the screens ands sync the phone. Not actually operate the phone.
Very frustrating !!!
- Sidewinder
- Weary Womble
Do the install from your PC using iTunes.
- David Bethel
I've found the install for apps in ITunes. It's the setup screens that drives me nuts. I couldn't tell you how many times I've typed an retyped a username and password in the last 5 days. It is ridiculous. And it seems everything on an iphone 5 is case sensitive.
Security is 1 thing, but the reality is if you loose a smart phone, you call have the thing disconnected.
I've ordered a bluetooth keyboard. It looks to be the answer. Thanks
- nick.bolton
- The Big Cheese
I find iTunes pretty frustrating, but there's a few transfer products out there which make it much easier (like a file manager) such as
http://www.imelfin.com/itransfer.html
and
http://www.leawo.org/itransfer/
and
- David Bethel
Got everything up and running <g>
$11.99 keyboard works great ! I would definitely recommend this to anyone who is new to touch screens or doing a new setup of a smartphone.
BATTOP Ultra-Slim Bluetooth 3.0 Wireless Keyboard
Now I get to figure out how work everything !
Thanks! -David
Thanks! -David
- Laughia
You should be interested of these two tools
* Data recovery software for iPhone 6+/6/5S/5C/5 http://www.any-data-recovery.com/produc ... overy.html
* iPhone data transfer, backup, management without iTunes http://www.any-data-recovery.com/produc ... nager.html
