Gmail deletes
anniebrion
Gmail deletes
Sat Nov 22, 2014 8:46 am
When deleting mail from my Gmail POP account, the emails are still left in the All Mail folder :thumbsdown
Re: Gmail deletes
Sat Nov 22, 2014 10:25 am
So when you pull to refresh, are the emails coming back?
anniebrion
Re: Gmail deletes
Sat Nov 22, 2014 10:31 am
No, in MWM they have gone but in my mail client the mail is in Gmails All Mail folder still.
I'm going to disable some filter rules to see if they are causing an issue.
anniebrion
Re: Gmail deletes
Sat Nov 22, 2014 10:50 am
Just done a bit more digging.
The emails come in and a filter moves them automatically to a folder by tagging with a label and moving them from the inbox. This procedure has not changed for years, MWMs list of emails is being updated when you delete and wash but this is on longer reflected back on Gmail server. So the emails are no longer being deleted from Gmail :thumbsdown
If I delete and email from Outlook via IMAP the email is removed from both MWM and outlooks server.
It looks like the delete from Gmail has been broken since beta 4.
Re: Gmail deletes
Sat Nov 22, 2014 11:14 am
Ok, I think we can fix this :) now we can replicate it. Thanks for letting us know
anniebrion
Re: Gmail deletes
Sat Nov 22, 2014 11:55 am
Glad I can help :devil just pleased that it's not just me :thumbsdown
Re: Gmail deletes
Tue Nov 25, 2014 1:58 pm
Is this fixed for you now?
anniebrion
Re: Gmail deletes
Tue Nov 25, 2014 10:54 pm
Brilliant :thumbsup I'll give it a test when some emails come in :ninja
dadto7
Re: Gmail deletes
Fri Feb 13, 2015 12:11 pm
I believe I have this same issue. Recently I've noticed that when I delete in MW Pro it does not show in MWP anymore but Thunderbird pulls in the emails I deleted in MWP for Gmail accounts.
I tried using the "recent:[email protected]" as shown in other posts for Thunderbird and that did not help. Can someone tell me what the settings in TBird and Gmail should be?
I'm using POP3 for both MWP and TBird because it is my understanding (and experience) if I use IMAP in TBird it will load the new emails before MWP has a chance to delete them.
Re: Gmail deletes
Fri Feb 13, 2015 12:23 pm
When you delete emails in MWP, can you press the 'Check Mail' button again just to make sure they're actually gone. You might need to turn off making Thunderbird launch after washing mail in Mailwasher>>Settings>>General>>Washing Mail, just to test this out.
It might be that the POP3 server is being blocked because it's being accessed at the same time as something else accessing it.
