I have finally entered all my email accounys into my PC and MWP (7.4).
This morning i got the MWM version 2 ... Since then ..... Disaster after disaster.
I can only sync some of the email addresses from MWP to MWM .. None of the gmail ones wil sync across.
All the deleted emails are going into trash .. And staying there .. I want them to get lost as they did before.
I am NOT a happy lad today ... i ve struggled to get the gmail accounts nto my ipad . i failed on them all and it was a nightmare to get them into my PC.
I usually use a mac but as yet there is no version for the mac . ill keep on hoping.
Any ideas or help please.
Regards,
Charles.
Gmail and ipad - Not working !!!
- nick.bolton
- The Big Cheese
Re: Gmail and ipad - Not working !!!
You'll need this later version of MW Pro to sync IMAP email accounts
http://cdn.firetrust.com/downloads/mail ... 112014.exe
The trashed emails will be limited to 100 and they'll drop out as more get added.
- anniebrion
You can use http://mailwasher.firetrust.com/ on a Mac in your web browser, it is what the apps use
- Sidewinder
- Weary Womble
Are you sure that GMail isn't rejecting the attempts as though it is an out sider. They typically send an email seeking authorization to allow. There is a time limit to respond.
- CharlesN
I downloaded, Removed old version and installed 7.4.1.
Unfortunately when I did th sync to get my gmail accounts to my ipad ...... They didnt go across .. they are all ticked in the MWP version .. I logged out on my ipad fully and back in again ... they didnt apear.
Im really not aving much luck today. I have had MWP for many years .. First time i have had these sort of problems.
Thanks for that.nick.bolton wrote:You'll need this later version of MW Pro to sync IMAP email accounts
- CharlesN
They are working on my PC ... Just cant get thm over to my iPad.
Sidewinder wrote:Are you sure that GMail isn't rejecting the attempts as though it is an out sider. They typically send an email seeking authorization to allow. There is a time limit to respond.
- Sidewinder
- Weary Womble
Different device, just as though I tried to access your accounts from my device.
CharlesN wrote:Sidewinder wrote:Are you sure that GMail isn't rejecting the attempts as though it is an out sider. They typically send an email seeking authorization to allow. There is a time limit to respond.
- Sidewinder
- Weary Womble
Are you using the V2 account log in on the PC?
Do you have the latest V2 on the iPad?
Did you use the same login credentials in the PC sync and your iPad?CharlesN wrote:Thanks for that.nick.bolton wrote:You'll need this later version of MW Pro to sync IMAP email accounts
- nick.bolton
- The Big Cheese
Yes I suspect in MailWasher Pro>>Settings>>Sync, you're logged in for version 1.4. Logout then login again and select 'Version 2.0' with the same credentials as your iPad.
- CharlesN
I have done that ... I have been syncing with V2 on my PC and on my iPad its he new Ver 2 that i downloaded as an update today from the Apple store.
Something somewhere is just failing all the time
Only problem is i cant find out whats the fail point.
nick.bolton wrote:Yes I suspect in MailWasher Pro>>Settings>>Sync, you're logged in for version 1.4. Logout then login again and select 'Version 2.0' with the same credentials as your iPad.
- nick.bolton
- The Big Cheese
There's no emails from Google in your Gmail inbox asking you to verify the device the account is being accessed from?
- CharlesN
No None and they are working on my PC
nick.bolton wrote:There's no emails from Google in your Gmail inbox asking you to verify the device the account is being accessed from?
- nick.bolton
- The Big Cheese
If you go to https://www.google.com/settings/security then down to Recent Activity, is there anything being blocked there?
What about giving it explicit permission via this https://support.google.com/accounts/answer/185833?hl=en
