MWM 2.0 won't let hotmail account on
Claud47
Sun Dec 14, 2014 7:33 am
On my iPad I updated MWM to 2.0 and I did everything right to set it up. When I sync it up with all my accounts from my desktop. All my accounts sync, but my Hotmail account. I have tried to manually add my Hotmail account, but I get my username and password incorrect. They are correct. How can I fix this problem.
Thank you,
Claudia
Re: MWM 2.0 won't let hotmail account on
Sun Dec 14, 2014 10:05 am
Claud47 wrote:On my iPad I updated MWM to 2.0 and I did everything right to set it up. When I sync it up with all my accounts from my desktop. All my accounts sync, but my Hotmail account. I have tried to manually add my Hotmail account, but I get my username and password incorrect. They are correct. How can I fix this problem.
Thank you,
Claudia
Is your hotnail account POP or IMAP?
Claud47
Sun Dec 14, 2014 1:04 pm
POP3, If that makes a difference.
Sun Dec 14, 2014 1:41 pm
Claud47 wrote:POP3, If that makes a difference.
Yes it make a lot of difference.
Two things:
Double check all your settings in MWM to make sure that all is well (no extra spaces etc.) according to this:
http://www.firetrust.com/hotmail_pop3
The other possibility is that your router or system is blocking the port.
Mon Dec 15, 2014 11:07 am
Hotmail, now Outlook.com are blocking POP3 by default on new accounts, so when you login to the website at hotmail/outlook.com go to Settings>>Options>>Connect devices and apps with POP, then enable it there.
Also, can you make sure the POP3 settings in MailWasher Mobile are like the following.
server: pop-mail.outlook.com
username: your email address
Port 995
POP3 button selected
SSL enabled
If you select IMAP then the setting are changed
server: imap-mail.outlook.com
Port 993
Claud47
Sat Jan 17, 2015 7:16 am
nick.bolton wrote:Hotmail, now Outlook.com are blocking POP3 by default on new accounts, so when you login to the website at hotmail/outlook.com go to Settings>>Options>>Connect devices and apps with POP, then enable it there.
Port 995
SSL enabled
Port 993
I have done this, Settings>>Options>>Connect devices and apps with POP, then enable it there.
But when I do this it won't work.
Port 995
SSL enabled
Sat Jan 17, 2015 8:13 am
Does it work if you select IMAP in Mailwasher Mobile, and change those settings? Could your password be incorrect?
Claud47
Mon Jan 19, 2015 5:56 am
No, my password cannot be incorrect. I wish you could post a picture of the screen what it suppose to look it. This is very frustrating.
Mon Jan 19, 2015 7:51 am
Can you visit this page
http://www.microsoft.com/en-nz/Account/ ... ivity.aspx
and look at your recent activity to see if there's anything there which needs attention, such as a security warning or wrong password. If you see unusual activity in the US at Amazon, that is our servers.
Mon Jan 19, 2015 10:13 am
Also, you should have received an email like this
Verify your account
We detected something unusual about a recent sign-in for the Microsoft account co*****@outlook.com. For example, you might be signing in from a new location, device, or app.
To help keep you safe, we've blocked access to your inbox, contacts list, and calendar for that sign-in. Please review your recent activity and we'll help you take corrective action. To regain access, you'll need to confirm that the recent activity was yours.
Claud47
Tue Jan 20, 2015 5:42 am
Thank you for your help. Hopefully one day I will my h***@hotmail.com on MWM 2.0.
