"Unable to contact server"
- Sidewinder
- Weary Womble
Re: "Unable to contact server"
Have you tried shutting the device off and then restarting it?
- johnnysaint
Yes, I've switched on/off, no difference.
I've also cleared app data and cache but no success.
Thanks anyway
Thanks anyway
You're not alone, mine doing the same....seems like could be Android devices effected. Guys looking into it.
- nick.bolton
- The Big Cheese
Yes, sorry about this. We had to renew our SSL certificate and there was a small configuration problem with the new certificate which wasn't immediately apparent.
- steveshank
I have the exact same problem with my wifi only Android tablet.
1st off, I couldn't get in on the web to my account from Firefox in Windows with any machine and had to reset the password.
I reset it to exactly the same password (I copy and paste, never type). That fixed the problem.
At the same time, I stopped being able to access from my tablet. The Same "Unable to contact server" error. I re-installed and that didn't help.
My guess is that the new server and the Android program have some criteria somewhere about what characters or how many will not be accepted for a password and my password is doing something your new server/ system / Android program doesn't like.
Does anyone know what the Android password acceptability rules are? Is there a list of unacceptable characters (within the standard unicode ascii set, nothing fancy). I really liked being able to use Mailwasher on my tablet.
- NickStrong
Hi - this problem has been happening for the last 48hrs or so. Previously all ok. Android app.
Cannot log in using the web url either.
Any assistance gratefully received !
- nick.bolton
- The Big Cheese
It's working all ok as far as I can see. Is it still not working for you?
- rdgusta
Also not working for me on Android Phone Samsung-SM-N910A, Android ver 6.0.1, security Patch Level Aug 1, 2017
- gpumarejo
I have the same problem past 48 hours or so. iPhone App. Please help. Thank you
- nick.bolton
- The Big Cheese
Where are you all from? Trying to work out if there's a route being blocked to our server for this. I'm not seeing any issues at all.
- rdgusta
I am using a VHP if that makes a difference.
Gus...
Gus...
