Syncing accounts
bardos
Syncing accounts
Fri Oct 02, 2015 2:27 am
I managed to create an account with the mobile app, but on syncing, it only synced 4 of 7 email addresses. 3 Gmail addresses were not picked up. Is there a limit on syncing?
Re: Syncing accounts
Fri Oct 02, 2015 2:55 am
Not sure about any limit but did you have the tick boxes checked for all seven accounts?
FT will be in later it about 3:00 AM to provide you with a definitive answer about the limits.
Fri Oct 02, 2015 2:57 am
What version of MWP did you do the Sync with. If you don't have 7.6 then you should update to that version and then try the sync.
bardos
Fri Oct 02, 2015 6:26 am
Sidewinder wrote:What version of MWP did you do the Sync with. If you don't have 7.6 then you should update to that version and then try the sync.
Yes, ticked all accounts and using v7.6
Fri Oct 02, 2015 8:31 am
Just a quick thought, uninstall 7.6 keeping the user settings and download/install 7.5 from here:
http://cdn.firetrust.com/downloads/mail ... 022015.exe
Fri Oct 02, 2015 8:34 am
What kinds of email accounts are the ones which did not sync? Gmail, outlook.com or ? Can you let me know what you have in the 'Account Description' field in Mailwasher Pro>>Settings>>Accounts>>General
bardos
Fri Oct 02, 2015 8:45 am
nick.bolton wrote:What kinds of email accounts are the ones which did not sync? Gmail, outlook.com or ? Can you let me know what you have in the 'Account Description' field in Mailwasher Pro>>Settings>>Accounts>>General
3 gmail accounts and my one hotmail account do not show up on the mobile app. In the Account Description field is just a name to identify the account.
Fri Oct 02, 2015 9:10 am
Gmail and Hotmail (outlook.com) both use extra security so will have blocked them being setup on the mobile version.
Q: I can't get my GMail account to work
A: Gmail has probably blocked your account from being used with MailWasher Mobile, so visit https://support.google.com/mail/bin/ans ... swer=78754 to choose the options there.
Q: I can't get my outlook.com account to work
A: Outlook.com has probably blocked your account from being used with MailWasher Mobile, so visit http://www.microsoft.com/en-nz/Account/ ... ivity.aspx and look at your recent activity to see if there's anything there which needs attention, such as a security warning or wrong password. If you see unusual activity in the US at Amazon, that is our servers.
bardos
Fri Oct 02, 2015 9:13 am
It's not a signing in problem. The accounts simply do not appear on the mobile app.
Fri Oct 02, 2015 9:58 am
They won't appear on there if they can't be verified. Mailwasher Mobile is hosted and at Amazon and if it can't be authenticated and login then it won't sync the account. You will either need to follow the steps in the Q&A above or add them manually (and still go through the steps in the Q&A)
