Sync bug in Android
Preben.Hedegaard
Sync bug in Android
Fri Oct 02, 2015 10:53 am
I'm using MWM on two different Android devices,
and on both i need to pull down 4-7 times, before all mailas are visible.
This is really annoying !
Devices: HTC ONE M8s smartphone and Samsung Galaxy Tablet
/Preben
Re: Sync bug in Android
Fri Oct 02, 2015 10:55 am
Hi
When you first pull down, MWM is going to the server(s) to collect the mail - this can take some time, if you wait a bit, then the mail will have had time to be collected from your accounts, then when you pull down again it should show the mail you expect. It's just a function of how long the mail takes to be collected from your email accounts - perhaps if we showed an indicator as to this progress then it would be more helpful
Fri Oct 02, 2015 12:02 pm
[quote="nick.bolton"]Hi
When you first pull down, MWM is going to the server(s) to collect the mail - this can take some time, if you wait a bit, then the mail will have had time to be collected from your accounts, then when you pull down again it should show the mail you expect. It's just a function of how long the mail takes to be collected from your email accounts - perhaps if we showed an indicator as to this progress then it would be more helpful[/quote
Suggestion sounds like a viable one. Problem is not just for Android, IOS is the same.
Preben.Hedegaard
Sun Oct 04, 2015 1:35 am
Yes, a progress indicator that stays until all mails is collected, sounds like a good solution!
Also remember the message at the buttom, now it says "synced a few seconds ago" even when this is not the case.
