Android MailWasher No Longer Syncing?
vpnavy
Sat Nov 28, 2015 4:12 am
Worked great for a while now it just does its thing, shows no mail and just says: "Synced a few seconds ago." Unfortunately, I have 30+ messages when I check on my PC. I have log'd off and on (android) and still get the same results. Any suggestions?
Thanks!
UPDATE: Everything is working fine now. This was my solution:
1. Went to Android MailWasher Pro
A. Uninstalled MailWasher
B. Reboot Android
C. Re-installed MailWasher (but didn't log back in)
2. Went to Desktop MailWashper Pro
A. Went to Settings
B. Log'd out
C. Log'd back in.
3. Went to Android MailWasher and Log'd in
4. Went to Desktop MailWasher and Sync'd, Sync'd again with Friends and Sync'd last time with Blacklist
5. Went to Android MailWasher and Log'd in.
BINGO - Living the dream once again!
Re: Android MailWasher No Longer Syncing?
Sat Nov 28, 2015 6:33 am
Thanks for the feedback, a bit surprised it took all this. Perhaps your email password had changed or something and it needed to by Sync'd again?
vpnavy
Sat Nov 28, 2015 7:34 am
Acutally, you just reminded me that a few times this week I was forced to log in again on the Android side. Anyway, I haven't changed my MailWasher password in a billion years, etc. Who knows - as long as it is working again.
vpnavy
Sun Nov 29, 2015 1:57 am
Well - back to it not sync'ng. I guess it is time to uninstall and move onto something else - bummer!
Sun Nov 29, 2015 7:18 pm
Ok, there's something odd going on which we've not been able to pin down yet. Working on it.
vpnavy
Sun Nov 29, 2015 11:08 pm
I am sure it probably something on my side since no one else is having the problem - now running K-9. Thanks for the reply.
Chariott
Fri May 05, 2023 4:20 am
I'm having the same syncing problem. All of my email accounts are showing up in in Mailwasher Mobile, but all are showing only emails from days ago. Non show recent emails. All email accounts update normally in Mailwasher Pro. When I go to Settings in Mailwasher Pro and click on Sync, the green progress line shows for one second, then green balls with white checkmarks show that all have been synced, but no new emails show up in Mailwasher Mobile.
Is there a way to delete an email account in Mailwasher Mobile and let Mailwasher Pro Sync reinstall it?
Fri May 05, 2023 7:23 am
Yes, no known issues on our end, can you please try restarting your device, if no better, yes, you can indeed delete the account and set it up again...
First, click the Gear icon in MW Mobile, and click X to delete your account/s,
then log off MW Mobile, (icon for this top L/H side in MW Mobile >> Logout)
then in MWpro click, Settings>>Sync>>Logout,
then log back in again and click "Mobile", and tick the accounts/lists you want to sync, then click Sync.
Open Mailwasher on your mobile, click "Log in", enter your email address and password, and you should be all set.....?
Chariott
Sat May 06, 2023 3:25 am
Yes. Your instructions worked perfectly. I first deleted one email account in MW Mobile to test the instructions. When that worked, I then deleted all accounts. After relogging in and syncing, all email accounts downloaded all emails up to date.
Thanks very much for your help.
Tony
Sat May 06, 2023 6:30 am
Fantastic, good to hear all is well again.. cheers!!
Chariott
Sat May 06, 2023 7:49 am
Not so fast.
All of my email accounts loaded and performed normally after following your instructions, except my two primary accounts, both with the same ISP. I've tried entering the account settings manually, but I keep getting the same red-backgrounded error message –
Your email provider has indicated that your email settings are not correct.
I've tried reentering the password and settings, but not having much luck. I've tried refollowing your original instructions, but cannot get those two accounts to be listed in MW Mobile.
Sat May 06, 2023 8:11 am
OK sure thing, in that case, if all your settings are indeed correct, there really is unfortunately not much more we can do, the current mobile version is very limited and has no logging to see where the error is, it's in desperate need of a update however we're currently working on the new PC version and cannot get started on this until after that's completed....
Note that the mobile version is a free app, so we really do need to get the paid PC 8.xx version released first so we can continue.
Sorry about that!!
Chariott
Sat May 06, 2023 8:29 am
Thanks for replying.
I may try deleting all email accounts in MW Mobile again, and hope that the two troublesome accounts get included with the next sync.
Looking forward to the new MW 8 and, hopefully a MW Mobile update.
Sun May 07, 2023 6:58 am
Yes, could be worth a try... I'd try syncing one account at a time, sometimes that works better too.... cheers!
Chariott
Tue May 09, 2023 7:10 am
[try syncing one account at a time/quote]
Good idea, but didn't work.
Took a look at the video of MWPro 8 on YouTube. Looks nicely improved. I'd like to try it when it's available.
