Mobile not syncing
anyoneinracks
Mobile not syncing
Thu Nov 16, 2023 1:08 am
Hi, Thanks for fixing the weekends problem with the desktop app. Have installed the new version, but now when I click "sync" on settings, sync, mobile I just get a red cross against the two accounts and friends and black lists. Mobile app says no accounts exist. Have shut down desktop and restarted, uninstalled and reinstalled mobile app, but no change.
johnnysaint
Re: Mobile not syncing
Thu Nov 16, 2023 4:13 am
Same problem here.
Thu Nov 16, 2023 8:48 am
Yes, sorry about that, seems that the login for MWM within MWpro is broken for this update, looking at it now, will be fixed for next release....
For the meantime though, you can setup the account manually if you wish.....
Open MW Mobile and click Create Account, after it is created and MW is logged in, click, "Add Email Account", and enter the details which you use within your email client, or what your ISP supplied and click Save.
If asked on the next screen for further details, you may need to check within your email clients mail settings, or with your ISP to find out what to enter there.
OR, we have a page here: http://www.emailsettings.email/ which tells you what settings each ISP uses.
