I have been running the trial version of OKInbox and quite liked how it worked, however I noticed on a few occasions looking at Event Viewer that the addin was taking a long time to load (between 7 to 8 seconds at times) and thus stalling the opening of Outlook. Is this due to the number of emails within a digest, as this would have a limiting effect on the number of emails that you could direct via OKInbox and also to the infrequency of Digest releases.
Thanks for your help
OKInbox Observations
- nick.bolton
- The Big Cheese
Re: OKInbox Observations
Hi
Do you mean when Outlook opens and loads the Add-in? Or when you click on a digest? We'll have an update in the next few days which will address the problem of digests taking a long time to open.
- Aardvark
Hi Nick,
I am talking about when Outlook opens. If you look in Windows Logs at the Application log and Filter for Outlook as the Event Source then you get to see the Boot Time for any Outlook Addins. Good to hear that you have an update to fix the digests taking a while to open. I had one with ten embedded emails and it took a fair while to open. My 15 day trial has now ended, when the update comes out am I going to be able to check it out by just installing over the top or will I have to completely uninstall and start from scratch with the new version.
Thanks.
Thanks.
- nick.bolton
- The Big Cheese
Thanks for letting me know about the boot time. For now, to get your trial back to square one, just go to the registry HKEY_CURRENT_USER\Software\Firetrust\OkInbox and delete the keys 0xb0, 0xb1 and 'registered to'. Pretty easy to circumvent for now
- Aardvark
Thanks for the update Nick. It might be worthwhile keeping an eye on the addin boot times as I think the increased times correspond to when you open Outlook and a new digest is being processed for the first time. I will reinstate my trial and carry on checking it out.
Thanks for the info
Thanks for the info
- nick.bolton
- The Big Cheese
- nick.bolton
- The Big Cheese
Ok, we've got a new version on the website. It should be much faster at loading the add-in on startup, plus displaying the digest emails.
http://www.firetrust.com/en/products/ok ... d/download
- Aardvark
Just downloaded this but when I run it I am getting a failure when it is trying to remove the ODBC components. I get an error box saying "There is a problem with this Windows Installer package. A program run as part of the setup did not finish as expected. Contact your support personnel or package vendor" When I okay that I then get the OkInbox installer saying that "the setup ended prematurely because of an error". System Log shows error 1722
- nick.bolton
- The Big Cheese
Thanks for letting me know. Which version of Outlook was it for? Sounds like the download got corrupted perhaps. If you could post the error log or send it to me [email protected] that would be helpful
- Aardvark
Hi Nick,
Just redownloaded in case it was corrupted but same story. Trying to install it for Outlook 2010 (32Bit). Will email extracts from error logs to you.
- nick.bolton
- The Big Cheese
Ok, I just re-uploaded it uncase it was somehow corrupted on the server. If you want to try and download again from here
http://199f0096ab9e839d49c4-f38e90dc860 ... .0.115.exe
- Aardvark
Doesn't look as though server copy is corrupted as I get the same results with your latest copy. The install gets to the point where it is trying to remove ODBC components, it opens a window with Windows/System32 and then it dies. Will email you screenshot. Was wondering whether I should uninstall and then try a fresh install?
- nick.bolton
- The Big Cheese
Thanks, if you have the 'install.log' file from Documents>>OkInbox, that would be helpful. I'll pass it on to the developers
I would try to uninstall, then re-install. Also, after you uninstall, remove the files from this location manually
C:\Users\{user name}\AppData\Roaming\Firetrust\OkInbox
and you could also try removing the 2 folders from
C:\Users\{user name}\AppData\Local\Apps\2.0
- Aardvark
Uninstalled and removed the files you suggested but still had to do one further thing which was run the Windows Installer Clean Up (the replacement for the old MSICUU) as OKInbox was still in there. After that was able to install the new version.
Also found an MSI log in my temp directory which may give you some info
- nick.bolton
- The Big Cheese
Thanks for this and the logs. It appears from the logs that you're installing the old version somehow.
15/01/2013 15:29:32 Version: OkInbox for Microsoft Outlook 2010 x86 1.0.2012 (10110)
15/01/2013 15:29:32 Check if database need to update
15/01/2013 15:29:32 Database version: 6
15/01/2013 15:29:32 Current database version: 6
This should be
15/01/2013 7:29:57 p.m. Version: OkInbox for Microsoft Outlook 2010 x86 12.01.2013 (10115)
15/01/2013 7:29:57 p.m. Check if database need to update
15/01/2013 7:29:57 p.m. Database version: 8
15/01/2013 7:29:57 p.m. Current database version: 8
At HKEY_CURRENT_USER\Software\FireTrust\OkInbox in the registry you should also see 1.0.115 as the version number
Perhaps try running the updater from http://cdn.firetrust.com/downloads/OkIn ... .0.115.exe (it's only 2.7MB)
Thanks for the info on the typo - now sure how we missed that!
This should be
