Setting up Netflix
Setting up Netflix
Tue Sep 30, 2014 8:44 pm
A short post, with pictures on enabling Netflix through HideAway.
We'll assume you already have created a logon account for HideAway and are now successfully logged on, note at this point with no rules enabled no internet traffic is being diverted.
First click My Rules >> click the Add Rule button.
Scroll through the list of predefined rules for the Netflix default rule and click Add
Select your desired location, in this case you want either California or Missouri >> click OK
And that's it! Later if you wish to disable or enable a rule, you can go into My Rules >> and just click the check mark to toggle between enabled/disabled. New rules are enabled by default.
anniebrion
Re: Setting up Netflix
Tue Sep 30, 2014 9:52 pm
Brilliant, works a treat :thumbsup
