Loading Error
- tiger1john
Loading Error
Please help. I can no longer load Hideaway. It hangs at a "Loading Rules" screen.
Re: Loading Error
Hi there
If you quit HideAway from the System Tray >> right click icon >> Quit. Then restart, does it load ?
- tiger1john
Re: Loading Error
Nope. Quitting and reloading, rebooting the PC - nada.
I tried reinstalling and it did not fix the issue. I don't know if this could affect this: I bought 3 licenses. When I made the 2nd install I used the file I had initially downloaded. There was no request to enter a license key on the 2nd install. Any link? I get the "Loading rules" hanging error on both PCs.
I tried a fresh install after deleting the Appdata folder ( I cannot remember its name now) but that did not help.
- TrustFire
Re: Loading Error
Did you try running HideAway after temporarily disabling your security system?tiger1john wrote:Please help. I can no longer load Hideaway. It hangs at a "Loading Rules" screen.
Re: Loading Error
Try deleting C:\Users\[your username]\AppData\Roaming\Firetrust\Engine\Local Storage\ and running HideAway again, that'll force you to logon again.
- tiger1john
Re: Loading Error
Thanks for the replies. No - I have no tried running it without the my anti-virus being enabled, I will check that. Good idea thanks.
I have already tried the route of deleting <<C:\Users\[your username]\AppData\Roaming\Firetrust\Engine\Local Storage\>> but to no avail.
It did work to initially, it just stopped working after a couple of days. It is a great app, very simple to use, just need to iron out this issue. Thanks for your support.
- TrustFire
In my case, the security component was my Firewall which was hampering the HideAway installation.
Re: Loading Error
It would more likely be the HIPS component - once you identify the security component, you could create an exception for HideAway.tiger1john wrote:Thanks for the replies. No - I have no tried running it without the my anti-virus being enabled, I will check that. Good idea thanks.
Re: Loading Error
Yeah it does sound like Firewall blocking, if you let us know what flavour software firewall you're using, will find a link to show how to create exception. I will too get programmers to create a logging version tomorrow that might tell us more.
- tiger1john
Re: Loading Error
Great, try this then http://windows.microsoft.com/en-nz/wind ... s-firewall and Add HideAway.exe as an exception. I'd expect that particular Firewall to work out of the box though, so not hopeful it'll fix.
- TrustFire
Re: Loading Error
Just an heads up . . . . . . . . . . . . . I use the native Windows Firewall built into the 8.1 Update 3, myself - since it is quite difficult to operate, have been using the free variant of Windows Firewall Control (a front-end GUI with an extremely light footprint, for the Microsoft firewall - makes it much easier to manage.)
- tiger1john
Re: Loading Error
No joy
Switching off anti-virus, adding program to firewall, no difference. Still hanging on loading.
Re: Loading Error
Keen for a remote session using TeamViewer ? I got my logging version but it's a funky thing to use, needs Chrome and swapping out some EXEs.
Adding logging into the regular EXE is in the works, but not feasible right now.
