Multiple issues with this application
richards
Sun Jun 07, 2015 10:32 am
This is one of a number of issues. What does it mean please - anyone?
I have emailed Firetrust about the other issues and await their reply.
Re: Multiple issues with this application
Sun Jun 07, 2015 1:56 pm
Hi there
Did you see this note about Kaspersky ? You want to ensure that HideAway is installed with Self Defence disabled, so if you didn't do that the first time around, disable that, uninstall HideAway then reinstall.
http://forum.firetrust.com/viewtopic.php?f=59&t=16500
rd
