Error upon start
recremar
Error upon start
Thu Jun 11, 2015 4:10 am
Program errors out within 5-10 secs upon loading. Attached is a png of the error message. System is Win 8.1 Pro, Intel i7, 16 gb mem, ssd. I have tried reinstalling and rebooting and always the same error. Solution/suggestions on how to resolve? Thanks.
hideaway error.png (7.99 KiB) Viewed 2573 times
Re: Error upon start
Thu Jun 11, 2015 1:12 pm
That's a new one to me
Can I get your first to post your installation log. In the folder C:\Program Files (x86)\Firetrust\HideAway there is the install.log file
If you can copy/paste the contents of that back here it would be appreciated
rd
Thu Jun 11, 2015 2:49 pm
That is an extremely rare error (for any program) - are you running HideAway in Compatibility Mode?
recremar
Fri Jun 12, 2015 2:01 am
Attached is the install log requested. As for compatibility mode it is the default. Trying administrator and/or Win 7 produces the same error.
Install.log
(1.36 KiB) Downloaded 138 times
Fri Jun 12, 2015 2:29 am
Can you try uninstalling and reinstalling into the default folder and see if that stops the crashes ?
recremar
Fri Jun 12, 2015 4:29 am
Resolved the problem. Ran sfc /scannow and it found errors it couldn't fix. Reviewed CBS.log and found two .json files were corrupt. Did google search and found this link - http://thetechcookbook.com/windows-8-up ... upt-files/. Ran the fix, rebooted and Hideaway loaded without error. Can now test program.
Fri Jun 12, 2015 11:30 am
Excellent, great to know in future as well.
Many thanks :thumbsup
