Taskbar/Tray
Pancake
Taskbar/Tray
Thu Aug 27, 2015 11:28 am
Why cant the icon be removed from the Taskbar and just have the one in the tray ?
Re: Taskbar/Tray
Thu Aug 27, 2015 12:13 pm
Yes, sounds like you just need to click Settings>>General>>Application and select, Minimise to, "System Tray" and click Save there.
Re: Taskbar/Tray
Thu Aug 27, 2015 1:25 pm
Pancake wrote:Why cant the icon be removed from the Taskbar and just have the one in the tray ?
In HideAway if you minimise it using the - icon it goes into the taskbar, but if you use the x button it minimises into the tray
Pancake
Re: Taskbar/Tray
Sun Aug 30, 2015 9:47 am
Ok.Cheers.
Settings I have. General and Application I don't see ?
Re: Taskbar/Tray
Sun Aug 30, 2015 9:52 am
gingbat wrote:Yes, sounds like you just need to click Settings>>General>>Application and select, Minimise to, "System Tray" and click Save there.
haha, sorry, yes the above is for MWpro.... :)
Pancake
Re: Taskbar/Tray
Sun Aug 30, 2015 9:55 am
That would account for the missing items. :lol:
Pancake
Re: Taskbar/Tray
Sun Aug 30, 2015 3:27 pm
Anyway...... When Hideaway starts it does put an icon in the tray but the Screen (My Rules) still remains on the desktop. If I hit the 'X' it still remains in place. If I minimize it will go down to the taskbar. In the taskbar if I click on close window it will shutdown taking the tray icon with it.
gmusgrave
Re: Taskbar/Tray
Mon Aug 31, 2015 12:46 am
I have the same problem: '_' minimises to Task Bar, and 'X' does nothing.
Also, my copy no longer auto loads when Windows starts – I have to start HideAway manually. Not sure if the two are related....
Pancake
Re: Taskbar/Tray
Mon Aug 31, 2015 9:47 am
gmusgrave wrote:I have the same problem: '_' minimises to Task Bar, and 'X' does nothing.
Go to Start->Run type in msconfig under the Startup tab see if the HideAway box is ticked.
Re: Taskbar/Tray
Mon Aug 31, 2015 2:11 pm
Pancake wrote:Anyway...... When Hideaway starts it does put an icon in the tray but the Screen (My Rules) still remains on the desktop. If I hit the 'X' it still remains in place. If I minimize it will go down to the taskbar. In the taskbar if I click on close window it will shutdown taking the tray icon with it.
That's odd, when HideAway starts it should detect if there is an account and should start in the tray unless it doesn't have an account to log into.
This is from reboot starts or just any manual start of HA ?
Pancake
Re: Taskbar/Tray
Mon Aug 31, 2015 7:45 pm
Its all from a normal start and it logs into the account ok then it goes to My Rules
Re: Taskbar/Tray
Mon Aug 31, 2015 7:47 pm
Pancake wrote:Its all from a normal start and it logs into the account ok.
Bugger. Will ask the guys if they know what might cause this.
