Suggestion: Tray Icon Menu
SeaCay
Fri Sep 11, 2015 12:49 pm
Hello HideAway support,
Do you think that you could add a menu item (or items) to permit the general enabling/disabling of HideAway (ie suspension of all rules). This suspension might also have a time-out function to conditionally/automatically re-enable rules.
I would like this function as some sites do not respond well to requests emanating from some servers issuing Geo-locations restricted by the site and/or their appropriate governments.
regards
SeaCay
Re: Suggestion: Tray Icon Menu
Fri Sep 11, 2015 12:57 pm
I'd be for this, will talk to the others about it.
What kind of intervals would suit, maybe the choice 5/10/30 minutes ?
SeaCay
Fri Sep 11, 2015 7:44 pm
Hello Rusticdog,
I think that the range of 5/10/30 minutes and 1 Hour would be suitable. I added the hour entry to allow consideration for those making say several purchases and finalizing financial transactions.
regards
SeaCay
Andrew42
Sun Sep 13, 2015 1:41 am
Good idea!. My Anti-Virus/Firewall has 10' 30' I hour, four hours and until next start-up.
Mon Sep 14, 2015 4:07 pm
Andrew42 wrote:Good idea!. My Anti-Virus/Firewall has 10' 30' I hour, four hours and until next start-up.
So would you want other times, or happy with initial suggestion of 5/10/30/60 minutes ?
Andrew42
Mon Sep 14, 2015 7:02 pm
I find 5' a little short; but no, unless you add "until next start up", go with the suggestion.
