I have HideAway set to route all traffic through Frankfurt. Today, not having rebooted my computer for a few days and running HideAway constantly I check my IP address: A Swisscom address not far away in Switzerland. Confused I checked it two more times: same result.
I logged out of HideAway and straight back in. Checked the address: somewhere close to Frankfurt.
Questions: Why should this happen?
Are we meant to log out and back in on a schedule to make sure the rules are still being enacted?
HideAway not Rerouting
Re: HideAway not Rerouting
Sorry, missed this post from the other day.
I'll ask the guys, see if they have any ideas on what might cause it. But no, you shouldn't need to logout/logon.
- Andrew42
- Active Albatross
Thanks. I have checked the ip address several times per day but the issue has not yet repeated itself although I have rebooted my computer every day since my last post.
- Andrew42
- Active Albatross
Not sure what "Hybrid Sleep" is. I have Windows 7 with a power setting on "Balanced". My PC is a laptop which is, most of the time, operated on a docking station with the lid shut and an external monitor. When attached to the mains,(most of the time), it is set to turn off the display after 10 minutes and sleep never.
- TrustFire
Andrew42 wrote:Not sure what "Hybrid Sleep" is.
- Andrew42
- Active Albatross
- TrustFire
Back to the drawing board then. Next time you do notice this happen, can you check under My Rules that your rule is active and doesn't have a strike through it, also hit the Edit Location button >> Save >> see if that kicks it back into life rather than a logout/logon. If that works ought to help us track down where it's going wrong.
- Andrew42
- Active Albatross
Will do. I can say now that the rule was active with no strike out when I noticed the problem.
