Rule for all webbrowsers and exclude some sites?
Caligula
Thu Jul 14, 2016 12:36 pm
I made a rule for all webbrowsers.
Now i want to exlude some sites like: .Norton.com/My bank etc..
How do i do that?
Thank you in advance
Regards,
Pieter
Re: Rule for all webbrowsers and exclude some sites?
Thu Jul 14, 2016 12:42 pm
Hi there
When you are in the rule creation screen, click Advanced >> then select the Spanner icon >> ou can then create your filters, and there is the Action at the top where you set to Exclude instead of Redirect. Also once you've finished with the rule creation, in My Rules, be sure to drag the exclusion rule above your browser rule, as you want the exclusion to take precedence.
Caligula
Thu Jul 14, 2016 12:55 pm
Thanks! :D
Regards,
Pieter
Regards,
Caligula
Thu Jul 14, 2016 12:59 pm
Forgot to add, leave the Process, IP and Ports blank, it's only the domain you need to enter e.g.
norton.com
Once you have created a filter, then click the Plus icon next to the spanner to create another filter for the next domain.
