Hideaway asks me to log in
gunzelguy
Wed Sep 21, 2016 8:05 pm
Why does my Hideaway shut down and not appear to be operating, and ask me to log in before loading my rules and running again?
Re: Hideaway asks me to log in
Wed Sep 21, 2016 8:12 pm
Hi there
How often is HideAway shutting down without you exiting the program ?
You could try installing this version as well, which may help http://cdn.firetrust.com/downloads/hide ... _140ev.exe
gunzelguy
Thu Sep 22, 2016 5:05 pm
Infrequently, but I check ocassionally and find it is not doing what I expect. It also does not appear to be redirecting some traffic even though I only have one rule active to redirect all traffic.
Thu Sep 22, 2016 5:15 pm
OK, try that above version. We've found on some setups HA stops working after certain Win Updates and the version above uses a stronger security certificate which we think can help this situation
gunzelguy
Thu Sep 22, 2016 6:01 pm
Thank you for your help. I have installed the latest version of Hideaway, and I can now see that all traffic except a small initial portion of 42kb is being redirected and encrypted. I will keep a close eye to see if Hideaway signs out and needs signing in again.
