Servers Down
- Andrew42
- Active Albatross
Re: Servers Down
Yeah HideAway1 has died on us, check out this post for more details from Nick http://forum.firetrust.com/viewtopic.ph ... 04#p110798
- Andrew42
- Active Albatross
Re: Servers Down
OK, understood, I have downloaded V2 but cannot find any sort of user manual. The opening screen asks what I would like to redirect of Internet Browsers or all computer, but I see nothing else. Am I meant to uninstall V1. Is the only thing possible either a toal redirect or a selected browser? What about exclusions etc. Frankly I'm a bit lost for lack of any user guide.
Re: Servers Down
Yeah sorry, I was a touch brief. Uninstall version 1, given that's now dead in the water.
Currently version 2 only has the options presented, choose what to redirect + country, hit Start. We're doing another quick update to add in Australia and Netherlands. That build just got driver approval via Microsoft so should be ready very soon.
The plan looking ahead for the next few weeks...
UDP Support - 3 weeks to go. Finish mid Feb.
Client side TCP/UDP - 4 weeks to go
UI/Client integration with Auto-Updates. - Finish mid-March (this is the part you're interested in most, rules and exclusions etc...)
Then a soft-release.
The demise of v1 is very awkward timing and put things in a bad situation, but unfortunately we cannot speed up the progress of v2, and that's just got to truck along as planned.
- Andrew42
- Active Albatross
Re: Servers Down
Thanks, I've done that. From what I can see I have to start HideAway 2 each time I log on? It does not operate like the old version where we logged on and stayed like that until we logged off?
- Andrew42
- Active Albatross
Re: Servers Down
Unffortunately I have now discovered that running HideAway 2 blocks my wireless printer. Is that what you would expect and,if so, is there a way around this?
Re: Servers Down
Ah dang, no that won't be until we've got the exclusions etc... sorted
Same issue that you had with HA1 I imagine http://forum.firetrust.com/viewtopic.ph ... 486#p98482
