Redirects May 24
Andrew42
Redirects May 24
Thu May 25, 2017 9:53 am
On my machine Los Angeles seems to direct to New Jersey and Oregon doesn't work: all others are fine.
Re: Redirects May 24
Thu May 25, 2017 12:09 pm
Hi there
Can you try restarting HA if not done already, should be version 3.3.0. We recently had to update Oregon to cater for a Netflix issue.
Andrew42
Thu May 25, 2017 7:50 pm
Thanks. My system had not updated to 3.3 and I could not get it to do so. However, now it has and Oregon is fine. LA still redirects me to New Jersey which is no bid deal as the country is right. I've attached a screen shot for your info.
HA redirect.jpg (491.14 KiB) Viewed 7547 times
Thu May 25, 2017 8:35 pm
Actually been told the server is in LA, some of these services can be a touch inaccurate.
https://whatismyipaddress.com/ says it’s in LA, so potentially more reliable to use.
Andrew42
Thu May 25, 2017 9:01 pm
It must be the Trump effect!
